Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Colorado Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Colorado Chapter Join Chapter, Leader: RIKIL
  #1 (permalink)
Old 07-16-2010, 10:41 PM
rikfish's Avatar
rikfish rikfish is offline
Garage is empty, add now
rikfish is gaining momentum as a positive member of FTE.
New Toy
I am now the owner of a 1968 Mustang Coupe. Car appears to be in pretty good condition, considering it is 42 years old. Body is straight, entire front suspension was rebuilt by previous owner. Engine is weak, I'll have to check it out to see if it needs a build. It's a 200 C.I. L6, 3 speed manual. No A/C, just a bare bones Stang. Drove it home about 50 miles or so ( Canon City to Pueblo), other than loose steering and a brake pull to the right it did ok. Interior needs to be redone as well. I think I got a good deal for $2500.
__________________
rikfish
'03 F150 4X4 XL, 5.4 etc....
'01 E350 Ext. 15 pass., XL, SD, 5.4 etc.....
68 Mustang Coupe, 200-6, not much else! (work in S L O W progress)
  #2 (permalink)
Old 07-17-2010, 11:43 AM
ceetwarrior's Avatar
ceetwarrior ceetwarrior is offline
1967 Ford F-100
ceetwarrior is starting off with a positive reputation.
Cool, got any pics?
__________________
-There's no replacement for Displacement
My Gallery
  #3 (permalink)
Old 07-17-2010, 09:55 PM
rikfish's Avatar
Check my album for a couple of pictures. I'll get some more up in the near future. Dog is demanding I take her out for a walk!
Worked on the car today, it has very little power, even for a 200. Found a lot of things a previous owner has changed, such as wiring the choke open, messing with the vacuum lines, etc. Trying to figure out the distributor advance as well. Dual diaphragm, no centrifical advance. I checked the plugs this morning, found 2 loose. All looked pretty clean, with the exception of #1 had a small amount of oil fouling, but it was one of the loose ones. The air cleaner appears to be a problem as it is a solid top, no opening for air! Removed it, tried a run around the block and gained a lot of power. I will do a compression check soon, too hot outside to spend much time (103 today) working.
I am going to a meet in the morning with the Southern Colorado Mustang Club. Hope to get introduced to some other early 200 owners. They're having a run up to Salida then a picnic. I have no plates yet, plus I am not real convinced the car is ready for any long drives!
__________________
rikfish
  #4 (permalink)
Old 09-11-2010, 07:43 PM
Hypoid's Avatar
Hypoid Hypoid is offline
Hypoid is gaining momentum as a positive member of FTE.Hypoid is gaining momentum as a positive member of FTE.
Pretty cool Rick! Any updates?
__________________
NO PRIDE-NO SHAME
'74 F-100 4x4: It's ugly, loud and smelly. Those are it's good points!
'96 Ranger XLT, 2.3L, 5-speed, 2 wheel drive.
Email me at Hypoids.haus at yahoo, visit me at RMFTC.com/forums
  #5 (permalink)
Old 09-12-2010, 05:24 PM
rikfish's Avatar
Not too much progress yet. Limited budget, as well as a very busy time with my work schedule. (State Fair, next Chile & Frijole Fest) Working mostly on the interior right now, but need to work front brakes as RF wheel cylinder leaks and it pulls pretty hard! Have made some exciting right turns a few times!!! Trying to decide which way to go engine-wise. It has the 200-6, which is soooo underpowered, or maybe toss a small block in. A lot of changes need to be made to accommodate a small block though.
__________________
rikfish
  #6 (permalink)
Old 09-16-2010, 12:08 PM
jthorngate3's Avatar
jthorngate3 jthorngate3 is offline
1986 Ford F-150
jthorngate3 has a great reputation on FTE.jthorngate3 has a great reputation on FTE.jthorngate3 has a great reputation on FTE.jthorngate3 has a great reputation on FTE.jthorngate3 has a great reputation on FTE.jthorngate3 has a great reputation on FTE.
42209261 Fordx4bronc3545
Very nice pick up Rik! Good luck with all the work. Should be a lot of fun once it's all done up nice. Congrats.
Hey Hypoid, any luck selling your unibody?
__________________
Josiah
86 F150 4x4 I6(offy DP, Holley 465cfm, EFI exhuast manifolds, walker y-pipe, ARP head studs, D.U.I. HEI distributor) C6-NP208F, 2 1/2" rough country lift, 32x11.5x15 Cooper Discoverer STT
2010 FFH...slowly accepting, MPG helps
  #7 (permalink)
Old 10-03-2010, 11:10 PM
rikfish's Avatar
Update on money pit. This weekend I installed new carpet, kick panels, sill plates, and 15" Grant wood steering wheel, and a chrome air cleaner. Not a lot of progress, trying to keep spending in check right now. Next to put in new upholstery front and rear, then on to dash replacement/repair, along with new weather stripping all around. Want to get the interior pretty well done before I start on body, motor, and brakes.
I hate to say it, but this was the first time I REALLY looked under the car. Found a previous owner had repaired a rotten out floor pan on the drivers side. Not a great job, but it will do for now. Otherwise, underside looks pretty good. Also found a previous owner must have modified the shifter or had a different tranny as the tunnel has been cut out somewhat.
__________________
rikfish
Tags
2010, diesel, ford, model, toy, truck, truks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
