1978 ignition module replacement - Ford Truck Enthusiasts Forums
Old 07-16-2010, 09:20 PM
Mbuchanon19 Mbuchanon19 is offline
Mbuchanon19 is starting off with a positive reputation.
hey guys ive got a 1978 f100 lariat 302. lately ive been having trouble dying and stalling and its not my carb or overheating. ive been told its more then likely my ignition module. i was wondering if anybody knew a place to get a pretty reliable one because ive heard these aftermarket ones arent very good at all. also if they just go out like people say they do is there a way to bypass the module? to be honest i dont know much about the functions of it or if there is an alternative to having one besides having efi or anything like that.
Old 07-16-2010, 09:29 PM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
Do yourself a favor and buy a genuine Motorcraft module, it will cost more up front but will pay for itself overtime when compared to the cheap overseas modules, if you do buy an off brand module buy two and keep one under the seat they tend to fail at the most inopportune time.
Old 07-16-2010, 09:58 PM
do you know the average lifespan of the motorcraft modules?
Old 07-16-2010, 10:01 PM
jade79 jade79 is offline
jade79 is gaining momentum as a positive member of FTE.
Quote:
I agree. I've also had good luck with NAPA's premium line.
Also, check the wires inside the distributor where they connect to the pickup coil. Mine had deteriorated from engine heat and broke off, making intermittent contact causing similar symptoms of a bad module.
Old 07-16-2010, 11:24 PM
smokeyb97's Avatar
smokeyb97 smokeyb97 is offline
smokeyb97 is starting off with a positive reputation.
Quote:
I don't know, but mine is the original module.
Old 07-16-2010, 11:54 PM
Quote:
If that's not a testament i don't know what is lol.
Old 07-17-2010, 01:41 AM
smokeyb97's Avatar
I've been lucky I guess, thought about getting a cheap one and putting it inside behind the seat, just in case.
Old 07-17-2010, 11:07 PM
thanks all really appreciate the advice
Old 07-18-2010, 11:38 AM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
Replacement off-brand modules are reverse-engineered from the original, and can fail quickly. It's not uncommon for the original module to last 25 years. I too have had good luck with Napa modules.
Old 07-18-2010, 06:31 PM
one more question, the one on there right now is some off brand made in china module and i cant tell what kind or a seriel number. on summit they have like 8 motorcraft modules and on the motorcraft website they have two is the dy983 the one i need for a 78?
Old 07-18-2010, 06:46 PM
My search shows it as a DY-893.
Old 07-18-2010, 07:35 PM
sry typo dy893* yeah thats what mine says too
What's the difference in ignition modules? Harkijr 1973 - 1979 F-100 & Larger F-Series Trucks 23 01-26-2016 10:25 PM
Duraspark module differences abyars111 1967 - 1972 F-100 & Larger F-Series Trucks 10 08-04-2015 05:55 PM
Ignition module problems again possibly 1979 300i6 1973 - 1979 F-100 & Larger F-Series Trucks 6 11-28-2013 10:30 PM
how to replace ignition module on 88 f150 (351) Machine140 1987 - 1996 F150 & Larger F-Series Trucks 5 05-27-2013 02:57 PM
Ignition control module wiring help!!!! tcrbraydn 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 23 11-14-2012 04:27 PM
Tags
1978, 1997, 351, 73, 79, buy, f100, f150, failing, ford, ignition, module, ranchero, replaced, replacement, truck, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
