What's good and bad about the 6.0L engine? - Ford Truck Enthusiasts Forums
Old 07-16-2010, 02:55 PM
HT32BSX115's Avatar
HT32BSX115 HT32BSX115 is offline
HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.
Howdy people!
I am starting to look for a 6.0L powered Excursion.
I have had a 94 diesel Suburban since I bought it new and I want another one (they don't make them) so, I'm considering getting an Excursion.
I have heard all sorts of "hearsay" things about the 6.0L engine....
What's the real deal? I am going to probably get one with less than 60,000 miles on it. I've found several with under 50,000 miles....
Are there any show stopping things I should look for and are there any mods I should do to it myself (and/or avoid if someone else did them)?
Cheers,
Rick
Old 07-16-2010, 04:02 PM
rickf92592 rickf92592 is offline
rickf92592 is gaining momentum as a positive member of FTE.
There is already a lot of information on this site. Search is your friend.
Old 07-16-2010, 04:14 PM
texans's Avatar
texans texans is offline
texans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to behold
Hey Rick. Check out bismic post about buying a used 6.0, also read the tech folder there is a lot of good info in there for you to look for. The main things I would look for in a 6.0 is as folows.
1. White resuidue around the degas bottle (could mean bad egr cooler/blown HG.)
2. Be sure there isn't an am intake on it (they are known to cause problems)
3. Use only oem filters (will-fit ones are bad)
4. It would be nice to know the maintance history (ie..get an oassis report)
5. see if head studs have been installed (would be nice if they are, but not nessary)
6. check all fulid levals
7. I wouldn't buy one that has had, or has, any off the self tunner ie..Bully dog, banks, edge. The only two I would be ok with having had is SCT, or Spartan. either one with custom tunes.
That is a start there will be others with more info that I haven't thought about yet. As far as mod you should do yourself. I would install a coolant filter first thing. Also consider getting gauges to include at least ECT, EOT, and fuel pressure. If you go the tuned route I would also get EGT's, Boost (depending on the year), and Trans Temp.
Old 07-16-2010, 05:37 PM
HT32BSX115's Avatar
Quote:
Thanks y'all!!
I have tried the search......it's pretty hard to search for general non-specific problems. You get a zillion responses.....
I have read suggestions from "avoid the 6.0L altogether" to "avoid certain years"!
There's not much choice if you want a fairly new low mile Excursion! The last ones were made in 05 or 06?
Thanks again!
Rick
Old 07-16-2010, 08:00 PM
Troy Buenger's Avatar
Troy Buenger Troy Buenger is online now
Troy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to behold
Quote:
Originally Posted by HT32BSX115 View Post
Thanks y'all!!
Thanks again!
Rick
The last year for the Excursion was 05 which used 04 engines!
Good Luck!
Old 07-17-2010, 09:07 PM
HT32BSX115's Avatar
Quote:
Good Luck!
Is that good or bad?
Old 07-17-2010, 09:21 PM
The 05 engines did recieve some updates, but I would say that is not necessarly a bad thing. If you made up your mind about purchasing an Excursion I would focus on purchasing an 05 model in hopes you may have a little warrenty left (only months at this point) and the option to purchase a Ford ESP plan.
If you kept that Chevy 6.5 engine running this long I would think you wouldn't have a problem with the Excursion. We had a 97 Chevy 6.5 turbo diesel and they had there share of problems.
Old 07-17-2010, 09:43 PM
HT32BSX115's Avatar
Yeah.. The just about ALL 94/95 models needed a replacement injection pump. I of course didn't replace mine until the warranty expired.....
I did all the work myself too. The OBD-I 6.5L diesel is pretty easy to work on.......(and luckily, GM reimbursed me for all the parts after the fact!)
I have no doubt I can work on a power Stroke engine too....I just don't want to get a model that might have been in a "lemon" year.....
I am hoping that there really was no particular year with big problems....
Old 07-17-2010, 10:28 PM
Generally speaking every year of the 6.0 life span recieved some level of improvements. The largest number of improvements came on the 04 model year and the smallest qty was with the 07 model year which doesn't apply to the Excursion.
If you do purchase an Excursion with a 6.0 then you will need to camp out here and read all the sticky's as there is alot go good info. If you do run into problems this is the place to be with alot of good help.
If you haven't driven a 6.0 psd your in for a treat. The power of the 6.0 will make that old 6.5 feel like a turd.
Good Luck...
Old 07-17-2010, 10:39 PM
hwybee22's Avatar
hwybee22 hwybee22 is offline
hwybee22 has a great reputation on FTE.hwybee22 has a great reputation on FTE.hwybee22 has a great reputation on FTE.hwybee22 has a great reputation on FTE.
I love mine and no major problems..... knock on wood. I always stay tune to FTE and just hang around to learn more about the 6.0. Maintenance is key!!!!
Old 07-18-2010, 09:34 AM
Curt's05's Avatar
Curt's05 Curt's05 is offline
Wiser by FTE
Curt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud of
This is my first diesel & i love it, tons of towing power, i would recommend the mods on this forum. Only thing is slow to warm up in below 20 degree mn weather, even with radiator cover.
Old 07-18-2010, 09:27 PM
HT32BSX115's Avatar
Good Luck...
I have no misconceptions about the power differences in the 6.5LGM IDI TD and any other diesel. They were only rated at about 190 hp and about 400 ft-lbs. When you realize that, it's ok.
I have about 185,000 onmy 6.5 and it's still running strong.
I want a bigger boat and I want to be able to tow it easily. The 6.5L just won't cut it. Also, I want a newer vehicle.
So the Excursion is the best choice IMHO. I don't need a big pickup...... (I have a 55 F-600!! with the 8x12 flatbed on it...I can haul more than most F250/350 pickups out there!!)
Old 07-18-2010, 09:39 PM
bradyracing bradyracing is offline
bradyracing is starting off with a positive reputation.
What is it about the 6.2 and 6.5 that it doesn't want to start when its warmed up?
2000 Ford Excursion w/ 7.3L: What's it worth? MAINE EXCURSION Excursion - King of SUVs 7 09-20-2016 08:33 AM
Need help with excursion purchase decision e_moreno70 Excursion - King of SUVs 12 04-21-2013 05:01 PM
looking at 00-05 diesel. 7.3 or 6.0? advice? hasteranger Excursion - King of SUVs 41 06-27-2011 05:42 PM
Excursion 6.0L Diesel - Cold Start Issues Chrisaudax Excursion - King of SUVs 6 02-07-2011 01:02 PM
Which years were most reliable? should I buy? goldsmje Excursion - King of SUVs 62 03-09-2008 09:59 PM
Tags
2003, 2005, 60, 60l, bad, edge, engine, f350, ford, fords, good, maker, motor, powerstroke, reports
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
