1993 shakes and shudders at startup
My 1993 7.3l idi 5spd shakes and shudders at startup. sounds like the flywheel. when I give it the gas it will go away. but everyonce in a while
while sitting at idle, it comes back. I also know someone that has a 94 automatic that does the same thing. Is it fuel, or flywheel out of alignment.
thanks for the help with screws shorting out in the cab. never would have figured that one out.
thanks.
thanks.
...bump.... automatics dont have a flywheel, its a flex plate. in your truck though if you think it may be the flywheel, you can always check a few things on it. when you shut down, does it make a clunk? does it shudder when you fire it up cold and warm or just one or the other? you may have air in your fuel lines causing what sounds like a miss. im sure others will chime in there.
if the automatic makes the clunking noise then your in big trouble. lol... were talking about the clunking noise for you man. could also be the issue with the shudder and shake but again, i think that could be a miss. fuel issue. air in the fuel lines, maybe bad injector. i would do a compression check first, then if those all check out alright fire the truck up and crack one injector line at a time and that will bleed the air out of the system.
Armyguy1993
05-14-2015 09:33 PM
jroehl
10-28-2011 06:14 PM
texa5
10-24-2003 06:19 AM
