interchangeable parts - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 07-16-2010, 06:23 AM
bstc00 bstc00 is offline
bstc00 is starting off with a positive reputation.
Hey, Im new to the site and some what new to the X. I have had mine for a couple months now and would like to change out my headlights and wanted to know if the 05-07 ones will work.
-I would also like to get a new grille as I dont like the one I have.
-Is there a way to get the cab lights on the X?
-One last qustion can I change out the side mirrors of the one with amber turn lights on them of a 08-10.
Thanks for the help.
Bryce
Old 07-16-2010, 06:45 AM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
Bryce
The answer to all your questions is: Yes!
You can do the complete 05-07 front end conversion, add some cab lights, and those gigantic powered 08-11 tow mirrors. The mirrors may require a little creative wiring, but when it's done you'll love it!
Old 07-16-2010, 11:08 AM
Slug-O Slug-O is offline
Slug-O is starting off with a positive reputation.
I want the mirrors bad... Got a Link on that???
Old 07-16-2010, 11:21 AM
JaySVX's Avatar
JaySVX JaySVX is offline
JaySVX is a name known to allJaySVX is a name known to allJaySVX is a name known to allJaySVX is a name known to allJaySVX is a name known to allJaySVX is a name known to all
Mirrors were $1600/each last I checked, but it's been a while.
And actually, everything is interchangable with everything, if you have a big enough hammer.
Old 07-16-2010, 04:09 PM
christianpaul1968 christianpaul1968 is offline
christianpaul1968 is starting off with a positive reputation.
hi all
I just replaced my rear tail lights with a smoked chrome set
a bit of await for them to be shipped to uk and a nice letter and bill from customs for inport tax anh handling fee but worth it my 04 ex looks like its fresh off the forcourt
regards chris
Old 07-18-2010, 09:24 PM
2000Exc 2000Exc is offline
2000Exc is starting off with a positive reputation.
i have a 2000 < Are the grills from all years interchangeable?
Old 07-18-2010, 10:00 PM
Quote:
99/04 if I'm correct...
Old 07-20-2010, 07:57 PM
SARGE/AF's Avatar
SARGE/AF SARGE/AF is offline
SARGE/AF is gaining momentum as a positive member of FTE.
Instead of just changing the mirrors, can you interchange the whole door from a 08 to a 05? this would do away with the wireing issues, door panel, as you only have the heated mirror wire, power, ground to connect.
Besides it would easier and most likely cheaper to just buy the whole door.
Sarge
Old 07-20-2010, 09:46 PM
wallz's Avatar
wallz wallz is offline
wallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud of
Sarge
Couple problems with that senario. First, after the 08's came out and those that didn't order the power mirrors tried to refit to power mirrors they figured out that the controls are in the computer system and not just the door switches. The other is the interior panels on the doors will be different, as ford doesn't have the newer ones for the back doors as the doors are diff than the sd's.
The rewiring is actually pretty simple. I'm not elecrically inclined and I found it around 4 out of 10. 10 being hard. It took longer to add the signal wire and running light than the rest of the new wiring for the power mirrors as my 02 didn't come stock with those options. Lots of posts on here on how to do the wiring to make things easier.
Old 07-21-2010, 10:10 PM
SARGE/AF's Avatar
Will have to check on that, never thought about it but I dont see how it could that much different because mine has the same features except for the electic folding ability the 08's have and mine dont. I have to manual fold mine.
As far as door panels, If the front is interchangable then the rear would be too, anyway I plan on custom interior panels for the rear doors and back doors.
Sarge
Old 07-21-2010, 10:18 PM
wallz's Avatar
Sarge
Rear doors of the sd pickups are about 4-6" shorter than that of the the X rear doors.
The features of the new mirrors thru the control on the door are totally different. It has been tried to no avail. Way faster, easier and doable to just add new switches for the fold/xtend feature, and the rest of the controls stay the same on the door switches. I looked into this when I changed mine, did a lot of reading on here for all the necessary info.
sputtering after sparkplug change 00excdiesel Modular V10 (6.8l) 29 12-19-2016 11:41 PM
98 Needs New Headlights MauleOne Ranger & B-Series 3 05-08-2014 05:09 PM
Interior lights wont work, Help?! Jteets75 1999 to 2016 Super Duty 11 11-14-2012 05:23 AM
1979 F150 Alt light wont go off? HonestEngine302 1973 - 1979 F-100 & Larger F-Series Trucks 14 04-25-2011 04:38 PM
'89 7.3 glow plug issue roadrunner01 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 04-18-2011 01:34 PM
Tags
1986, 2000, 2003, 2010, bronco, duty, enthusiasts, excursion, expedition, f150, f250, ford, forums, interchangeable, parts, super, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
