Headlights only work on high beam - Ford Truck Enthusiasts Forums
Old 07-16-2010, 12:19 AM
Budman1962's Avatar
Budman1962 Budman1962 is offline
Budman1962 is starting off with a positive reputation.
I bought a 97 f150 stepside. I have been working on a few problems on the truck. One problem I can't figure out is the headlights. There is no power going to them on low beam. Is there a fuse or relay that could be out. I don't have an owners manual. Thanks
Old 07-16-2010, 07:21 AM
93 mix 'n match's Avatar
93 mix 'n match 93 mix 'n match is offline
93 mix 'n match is gaining momentum as a positive member of FTE.93 mix 'n match is gaining momentum as a positive member of FTE.
there is a relay. go to autozone and buy a haynes manual.
Old 07-16-2010, 07:24 AM
Budman1962's Avatar
Thanks for the reply. Is there a separate relay for high and low beam?
Old 07-16-2010, 07:28 AM
im not sure, but i think so. id go look but mines at the alignment shop.
Old 07-16-2010, 10:36 AM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
read page 209--- then download the book
http://www.motorcraftservice.com/pub.../02f12og4e.pdf
Old 07-16-2010, 04:47 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Quote:
Uh, NO!. There is no relay in the low-beam (or high-beam) circuit on a 97.
The output of the MFS (Rd/Bk wire) splits to two separate fuses (under-dash F28 and F26) that individually protect the left and right low-beam headlamp circuit. There is nothing else in the circuit.
Check the output of the MFS at the two fuses.
Old 07-17-2010, 12:12 AM
Budman1962's Avatar
Thanks for the replies. I checked the fuses and they are ok. Tomorrow I will check the voltage at the fuses. If nothing there I will disassemble the MFS.
Old 07-17-2010, 01:17 AM
mikesheldon mikesheldon is offline
mikesheldon is starting off with a positive reputation.
there is a chance that both headlight bulb filaments have gone on high beam, maybe one went a wile ago and you didnt notice, or it is your actaul switch
Old 07-17-2010, 09:46 AM
Yep, there is a chance that both bulbs have gone. The voltage check at the two fuses will give him guidance on which half of the circuit has the fault.
Old 07-17-2010, 12:08 PM
Budman1962's Avatar
No power to ether fuse 26 or 28. I checked it with the head light switch on. I will open up the MFS next.
Old 07-17-2010, 01:14 PM
Budman1962's Avatar
Fixed !! I disassembled the MFS and cleaned all the contacts with a scotch brite pad and electronic cleaner. Then I put a thin coat of dielectric grease and resembled it. It is working great. Thanks everyone for the help.
Budman
2007 Passenger side low beam problem mechasus Escape & Escape Hybrid 10 01-20-2017 09:36 AM
Headlight Problem and Random Connector Under Dash? DaMonsterMonster 1987 - 1996 F150 & Larger F-Series Trucks 6 11-29-2015 09:23 PM
1965 headlight problem mustangpt 1961 - 1966 F-100 & Larger F-Series Trucks 2 04-22-2015 10:59 PM
2000 f 250 headlights go out when I hit the low beam switch! crisnbecky 1999 to 2016 Super Duty 9 12-04-2010 10:10 AM
High Beams Work, No Low Beams? Weezman 1978 - 1996 Big Bronco 4 09-09-2008 06:04 PM
Tags
150, 93, 97, 98, beam, beams, f250, ford, headlight, headlights, high, low, truck, work, working, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
