How high is the oil temp? Do you know the temp difference between the coolant and the oil? If it constantly exceeds 15 degrees your oil cooler is bad, as Rick said.
250 is way to high, most likely burnt the oil by now.. replace the oil cooler asap as said and change the oil and coolant. Along with a vc.9 flush.
While I agree that he needs to zero in on the cooler, intermittant 250 deg oil isn't the end of the world, especially for synthetics.
Also, it is important where the sensor is for the oil, post-cooler or pre-cooler. Your engine sees 250 deg oil more than you'd like to know with a turbo.
True; I was taking it as running steady at 250. ....
