Flat Black Rustoleum Paint Job - Ford Truck Enthusiasts Forums
Old 07-15-2010, 08:49 PM
zerfetzen's Avatar
zerfetzen zerfetzen is offline
zerfetzen is starting off with a positive reputation.
Has anyone done this with a roller or a foam brush? I tried it on the side of the bed with a 4" foam brush, and I later could see vertical lines where I brushed, plain as day.
For kicks, I wet sanded over the brush marks, and it went away, and you couldn't tell I used a brush, but it took on a shine to it, which of course I don't want because I'm going for flat.
I gave up and tried Rustoleum's Hunter Green, which comes out medium green, not dark, and my heart's just not in it.
There are a lot of websites and videos showing how to do Rustoleum with a roller or brush, but I've only found shiny paint.
Any tips here on how to do flat black and make it look decent, not like it was rattle canned? Thanks.
Old 07-15-2010, 09:23 PM
hp246 hp246 is offline
hp246 is starting off with a positive reputation.
Sounds like the $100 paint job that was written about a couple years ago in Car Craft or Hot Rod. The used Rustoleum, brushed each coat then sanded like hell. As I recall it took about 7 coats of paint with color sanding after each coat. Took a couple weeks to let set between each coat after letting it set up.
Some guys are using a flat black tractor paint sold by John Deere, although I understand someone is making it for John Deere and also sells under the home label for quite a bit less.
You could probably buy a decent BC/CC system with a flattening agent in the clear coat for a couple hundred bucks from one of the mail order discount paint houses.
I've used these guys for supplies and have been quite happy: http://www.smartshoppersinc.com/
Old 07-15-2010, 09:59 PM
Blown 331's Avatar
Blown 331 Blown 331 is offline
Blown 331 is gaining momentum as a positive member of FTE.
If the rustoleum hunter green is not dark enough for you then just mix a little rustoleum black in with it. I've actually done this exact thing and it worked out great. It turned out a little olive green looking (but dark), I think if you throw a little blue in there it would be a pretty decent color.
Old 07-15-2010, 10:02 PM
CHELLIE's Avatar
CHELLIE CHELLIE is offline
CHELLIE is gaining momentum as a positive member of FTE.
You have to Spray paint on, to have it look decent, I belive you can get a paint thinner for rustoleum to thin and spray the paint on with.
http://www.harborfreight.com/air-too...gun-47016.html
http://www.harborfreight.com/air-too...sor-90234.html
Old 07-15-2010, 10:06 PM
zerfetzen's Avatar
I really like the Rustoleum idea and am bound and determined to make it work.
If I mix my paint, say 50/50 Hunter Green and Gloss Black, that would probably be a shade I like. But will I be able to get the mixture right every time? A year from now, if I get a ding and want to redo that spot, will a 5% error in mixture look like hell?
Otherwise, it seems like shiny Rustoleum is awesome, and so easy to work with.
Is there a way to do flat black but not have lines where you did it in sections?
If not, I think I'll try the 50/50 hunter green / gloss black route.
Old 07-15-2010, 10:08 PM
zerfetzen's Avatar
That's what I thought, flat colors probably have to be sprayed. Thanks.
Old 07-15-2010, 10:22 PM
Blown 331's Avatar
I think the 50/50 hunter green and gloss black will be too dark. I'm speaking from experience here. It will most likey look totally black. And you should be able to get the mixture exactly the same every time if you use a measuring pail. Personally I'd try 75% hunter green, 20% black and 5% blue. You'll see what I mean about not as much black and maybe some blue once you experiment. I've never done the blue thing but I think it would turn out better.
Old 07-16-2010, 08:32 AM
zerfetzen's Avatar
You may be right, and your suggested mixture sounds interesting and worth a try. Keep in mind that even though Rustoleum calls it hunter green, and even though the color looks dark on the label, the actual color is a medium green, maybe even light. A neighbor walked by, complemented it, and asked if it was apple green.
That's why I was thinking it needs that much black to get it to actual hunter green. I had a '79 dentside in the '80's in high school that was dark jade metallic or whatever the dark green color is, and I loved it.
For what it's worth, I tried Rustoleum's Royal Blue (I think it was), because the label looked like a darker blue, and dark blue is the truck's original color. I got it on there, and it was baby blue or sky blue. The actual color wasn't just a little bit lighter, it was a lot lighter. I don't know what Rustoleum's problem is with advertising and naming their colors.
I saw someone on here do their truck Safety Red, and it looked awesome, and like Rustoleum got the color right, so I guess their problem is only with their darker colors.
Their flat black looked great, if I only knew how to apply it right. Who knows, maybe I'll give up on the foam brush method that looks so great with shiny colors and spray bomb it flat. I really like dark green, but flat black is preference #1.
Old 07-16-2010, 08:37 AM
zerfetzen's Avatar
FYI:
This isn't my truck of course, but here's a picture of what shade of green Rustoleum's hunter green is:
Jeff's Bronco Graveyard - Reader's Ride #6425: 1984 Ford F-Series Pickup
(notice his truck is in the shade. My neighbor's right...get it in the sun and it looks like an apple)
...and here's the label for Rustoleum:
RustOleum.com
I don't know how to activate the links on here, but they can be copy/pasted into a browser.
Old 07-17-2010, 12:20 PM
coz coz is offline
coz is starting off with a positive reputation.
I painted mine with john deere blitz black. I sprayed it with a 19.00 harbor freight gun. It came out awesome. I have never painted before and it looks like a pro did it. Total cost about 90.00.
Old 07-17-2010, 12:37 PM
AK FORD GUY's Avatar
AK FORD GUY AK FORD GUY is offline
AK FORD GUY is gaining momentum as a positive member of FTE.AK FORD GUY is gaining momentum as a positive member of FTE.
Quote:
That looks great.
If I can find the Blitz Black up here, that's what is going on my 68 F100.
Old 07-17-2010, 12:52 PM
Blown 331's Avatar
Since it's a John Deere color just get it from a John Deere dealer.
Coz- that looks great. Did you do the body work or get nice parts or what?
Old 07-17-2010, 12:54 PM
FordmanShane's Avatar
FordmanShane FordmanShane is offline
FordmanShane is starting off with a positive reputation.
second, that paint job looks hella nice
Old 07-17-2010, 01:10 PM
The dealer up here does not stock it and wants to charge an arm and a let to get it sent up here. We'll see, I have a bunch of time before I get to that step.
Old 07-17-2010, 01:22 PM
Quote:
There are some tractor forums with John Deere dealers as sponsors. Sorry I don't have the links in my computer anymore, but you should be able to Google them. They advertise competitive pricing on parts. I'd bet they would ship you the paint you need reasonably if they're used to dealing online.
Rustoleum Roll-On Paint Job Jayman1976 1973 - 1979 F-100 & Larger F-Series Trucks 19 11-12-2014 02:17 PM
Paint That Rusty Ol' Ford Truck For $50 Vacationtime247 1987 - 1996 F150 & Larger F-Series Trucks 76 01-30-2014 10:36 PM
Rustoleum Paint Mixture For Frame Roger T. Pipe 1987 - 1996 F150 & Larger F-Series Trucks 44 08-05-2013 05:38 PM
Suggestions for painting vintage license plate carnut122 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 08-22-2011 08:42 PM
Paint That Rusty ol' Truck For $50 Vacationtime247 1987 - 1996 F150 & Larger F-Series Trucks 8 12-03-2010 10:28 PM
Tags
black, cheap, f150, f250, flat, ford, green, hunter, job, paint, roller, rustoleam, rustoleaum, rustoleum, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
