1997 F250, will not start
Old 07-15-2010, 07:01 PM
Rowan's Avatar
Rowan
Rowan is offline
Recently while making a short trip the above mentioned truck started missing. When I depressed the accelerator nothing happened, no power.
Holding down the accelerator the truck gained power and ran for 14 km
w/no recurrence of the afore mention loss of power, however, shortly after it lost Power again, and finally quit and would not start. I do believe it is something to do with the fuel pump, as when the water drain valve is open and I turn on the key there is no pressure and no fuel comes out of the fuel filter container. I am not sure where the fuel pump is located - the vehicle has 2 tanks and a switch. All fuses were checked and no problems found.
Old 07-15-2010, 07:14 PM
427 fordman's Avatar
427 fordman
427 fordman is online now
Sometimes the bowl won't drain till the cap is loosened. Have you changed the fuel filter and cleaned the screen in the bowl ( just down from top on drivers side in the bowl)? Fuel pump is below and behind the fuel filter canister. Check the fuel pressure with a tire gauge on the schrader valve.
Are there any codes? CEL come on? Recent oil change? HPOP resevoir full?
Also, welcome to fte. There's some really good help on here, I do what I can but there are a lot better.
Old 07-15-2010, 07:19 PM
fordpride's Avatar
fordpride
fordpride is offline
When trying to start does the tac move and do you have smoke coming out of the tailpipe
Old 07-15-2010, 07:40 PM
427 fordman
Ya, could be cps
OverHeight
06-22-2011 07:19 PM
rotun
02-06-2011 10:28 AM
tomtek
05-12-2010 10:40 AM
99F150
04-08-2005 03:21 PM
rgd420
10-19-2004 09:00 PM
Quick Reply: 1997 F250, will not start
