1997 F250, will not start - Ford Truck Enthusiasts Forums
Old 07-15-2010, 07:01 PM
Rowan Rowan is offline
Rowan is starting off with a positive reputation.
Recently while making a short trip the above mentioned truck started missing. When I depressed the accelerator nothing happened, no power.
Holding down the accelerator the truck gained power and ran for 14 km
w/no recurrence of the afore mention loss of power, however, shortly after it lost Power again, and finally quit and would not start. I do believe it is something to do with the fuel pump, as when the water drain valve is open and I turn on the key there is no pressure and no fuel comes out of the fuel filter container. I am not sure where the fuel pump is located - the vehicle has 2 tanks and a switch. All fuses were checked and no problems found.
Old 07-15-2010, 07:14 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Sometimes the bowl won't drain till the cap is loosened. Have you changed the fuel filter and cleaned the screen in the bowl ( just down from top on drivers side in the bowl)? Fuel pump is below and behind the fuel filter canister. Check the fuel pressure with a tire gauge on the schrader valve.
Are there any codes? CEL come on? Recent oil change? HPOP resevoir full?
Also, welcome to fte. There's some really good help on here, I do what I can but there are a lot better.
Old 07-15-2010, 07:19 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
When trying to start does the tac move and do you have smoke coming out of the tailpipe
Old 07-15-2010, 07:40 PM
Ya, could be cps
No power on cold start HELP! OverHeight 6.0L Power Stroke Diesel 23 06-22-2011 07:19 PM
429 f.i. "miss" on acceleration rotun Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 02-06-2011 10:28 AM
2007 Explorer Sport Trac 4.0 Lack of Power, Stalls tomtek Explorer, Sport Trac, Mountaineer & Aviator 9 05-12-2010 10:40 AM
Leaking fuel pump 99F150 1961 - 1966 F-100 & Larger F-Series Trucks 9 04-08-2005 03:21 PM
460 efi fuel problem rgd420 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 1 10-19-2004 09:00 PM
Tags
1997, 73l, diesel, f250, ford, powerstroke, start, starting, tac, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
