1995 F150 5.0 - Wont run on front fuel tank
Old 07-15-2010, 05:59 PM
rlh68050's Avatar
rlh68050
rlh68050 is offline
My (new to me) 1995 5.0L F150 will not run on the front tank. When I bought it from my son he said that he just was using the front tank a month or so ago but had switched to the rear when the front went low. I filled up the front (fuel gauge works) but the truck will not start. Flip the switch back to the rear and it fires right up. Am I correct in thinking that the pump in the front tank is bad? It's weird because my son said that he was just running on it.
Old 07-15-2010, 06:47 PM
f-150_1993's Avatar
f-150_1993
f-150_1993 is offline
Try this. With your truck off select front tank and check if the front tank pump runs. If it doesn't or it is very weak it probably doens't have enough pressure therefore truck won't start. What if you start your truck with the rear tank and change it to front. Will it try to stay running?
Old 07-15-2010, 11:50 PM
rlh68050's Avatar
rlh68050
rlh68050 is offline
I cannot hear the pump run at key up with the switch set to front. With the switch set to rear I can hear a pump run. If I switch it while it's running it will run for a few seconds (fuel still in the line) then die.
Old 07-16-2010, 07:39 AM
f-150_1993's Avatar
f-150_1993
But you said it was running... maybe it's an electrical problem rather than the pump going out. I'm not sure that when the switch goes out both pumps don't run or just one of the two tanks stops working. Hey forgive but I am having a wisdom tooth extraction and I might not get on but i'll try. Hope someone else chips in though.
Old 07-16-2010, 01:09 PM
Ford Breakdown's Avatar
Ford Breakdown
Ford Breakdown is offline
The '95 F-150 had some sort of switching valve problem between the two tanks. I remember installing a wiring harness fix at one point that went quite smoothly with the bed off: search this forum for threads on Dual Tank problems or repairs
Old 07-16-2010, 02:55 PM
subford's Avatar
subford
subford is offline
More than likely the front pump is bad, that is the they quit most of the time.
snorindad
04-02-2017 07:01 PM
Big350
11-11-2013 11:31 AM
jzombakis
06-21-2012 09:31 AM
oreodog
07-04-2011 11:01 AM
biggyman50
10-12-2010 09:44 PM
Quick Reply: 1995 F150 5.0 - Wont run on front fuel tank
