Rear axle tag codes
Rear axle tag codes
Code Application Ring Gear And Pinion NL
or
L Axle
Shaft
Splines Additional
Information
Ratio Diameter
of RG
S406-B Ford F250SD, F350SD Pickup ‘99 3.73 10.50 NL - -
S406-C Excursion '00
Ford F250SD, F350SD Pickup ‘99-01 3.73 10.50 NL - full-float
S406-E Ford F250SD, F350SD Pickup ‘99-01 3.73 10.50 NL - -
Lincoln Continental '85
Lincoln Mark Series 85 3.08 7.5 NL 28 -
S406-F Excursion '00
S406-H Ford F250SD, F350SD Pickup ‘00-01 3.73 10.50 NL - -
S407-E Lincoln Continental '85
Lincoln Mark Series 85 3.27 7.5 L 28 -
S407-E Lincoln Continental '87
Lincoln Mark Series 87-92 3.27 8.8 L 28 -
S407-F Lincoln Continental '87
S408-E Lincoln Continental '85
S409-B Ford F250SD, F350SD Pickup ‘99 3.73 10.50 L - -
S409-C Excursion '00-01
Ford F250SD, F350SD Pickup ‘99-01 3.73 10.50 L - -
S409-E Ford F250SD, F350SD Pickup ‘99-01 3.73 10.50 L - -
Lincoln Mark Series 85 3.73 7.5 NL 28 -
S409-F Excursion '00-01
S409-H Ford F250SD, F350SD Pickup ‘00-01 3.73 10.50 L - -
S410-A Excursion '00 3.73 10.50 NL - -
S410-B Excursion '00 3.73 10.50 NL - -
S410-E Lincoln Continental '85
Lincoln Mark Series 85 3.73 7.5 L 28 -
S411-A Excursion '00 4.10 10.50 L - full-float
S411-B Excursion '00 4.10 10.50 L - full-float
S411-E Lincoln Continental '85
S412-A Excursion '00 3.73 10.50 NL - -
S412-B Excursion '00 3.73 10.50 NL - -
S412-E Lincoln Continental '85
S413-A Excursion '00 3.73 10.50 L - -
S413-B Excursion '00 3.73 10.50 L - -
S413-E Lincoln Continental '85
Lincoln Mark Series 85 2.73 7.5 NL 28 -
S414-E Lincoln Continental '85-87
Lincoln Mark Series 85-87 2.73 7.5 NL 28 -
S414-F Lincoln Continental '87
Lincoln Mark Series 87 2.73 7.5 NL 28 -
S415-A Excursion '00 4.30 10.50 L - full-float
S415-B Excursion '00 4.30 10.50 L - full-float
S415-E Lincoln Continental '85
Lincoln Mark Series 85 2.73 7.5 L 28 -
S416-E Lincoln Continental '85
S421-B Ford F250SD, F350SD Pickup ‘99 4.30 10.50 L - -
S421-C Excursion '00
Ford F250SD, F350SD Pickup ‘99-01 4.30 10.50 L - full-float
S421-E Ford F250SD, F350SD Pickup ‘99-01 4.30 10.50 L - -
Lincoln Continental '86
Lincoln Mark Series 86 3.27 8.8 L 28 -
S421-F Excursion '00
S421-H Ford F250SD, F350SD Pickup ‘00-01 4.30 10.50 L - -
S422-E Lincoln Continental '86
Lincoln Mark Series 86-92 8.8 NL 28 -
S423-E Lincoln Continental '86-87
Lincoln Mark Series 86-87 3.08 8.8 L 28 -
S423-F Lincoln Continental '87
Lincoln Mark Series 87-92 3.08 8.8 L 28 -
S424-E Lincoln Continental '86-87
Lincoln Mark Series 86-92 3.27 8.8 NL 28 -
S424-F Lincoln Continental '87
Lincoln Mark Series 87-92 3.27 8.8 NL 28 -
S431-B Thunderbird 87-92 3.55 8.8 L 28 -
S431-C Thunderbird 88 3.55 8.8 L 28 -
S431-D Thunderbird 88 3.55 8.8 L 28 -
S433-B Thunderbird 87-88 3.73 8.8 L 28 -
S433-C Thunderbird 87-88 3.73 8.8 L 28 -
S445-C Cougar 88 3.08 7.5 L 28 -
S460-B Ford F350SD Pickup ‘99 3.73 10.50 NL - -
S460-C Ford F350SD Pickup ‘99-01 3.73 10.50 NL - -
S460-E Ford F350SD Pickup ‘99-01 3.73 10.50 NL - -
S460-F Ford F350SD Pickup ‘99-01 3.73 10.50 NL - -
S460-H Ford F350SD Pickup ‘00-01 3.73 10.50 NL - -
S461-B Ford F350SD Pickup ‘99 3.73 10.50 L - -
S461-C Ford F350SD Pickup ‘99-01 3.73 10.50 L - -
S461-E Ford F350SD Pickup ‘99-01 3.73 10.50 L - -
S461-F Ford F350SD Pickup ‘99-01 3.73 10.50 L - -
S461-H Ford F350SD Pickup ‘00-01 3.73 10.50 L - -
S501-A Cougar, Thunderbird 89 3.27 7.5 L 28 -
S501-B Cougar, Thunderbird 89-93 3.27 7.5 L 28 -
S502-A Cougar, Thunderbird 89 3.27 7.5 L 28 -
S502-B Cougar, Thunderbird 89-93 3.27 7.5 NL 28 -
S508-A Cougar, Thunderbird 90-97 2.73 8.8 L 28 -
S509-A Cougar, Thunderbird 89 2.73 8.8 L 28 -
S509-B Cougar, Thunderbird 89-93 2.73 8.8 L 28 -
S510-A Cougar, Thunderbird 90-94 3.08 8.8 L 28 -
S510-F Cougar, Thunderbird 95-96 3.08 8.8 L 28 -
S511-A Cougar, Thunderbird 89 3.27 8.8 L 28 -
S511-B Cougar, Thunderbird 89-93 3.27 8.8 L 28 -
S513-A Cougar, Thunderbird 89 3.08 8.8 L 28 -
S513-B Cougar, Thunderbird 89-93 3.08 8.8 L 28 -
S602B Bronco II, Ranger 84-85 3.45 7.5 NL 28 -
S602C Bronco II 86 3.45 7.5 NL - -
S602D Bronco II 87-88 3.45 7.5 NL - -
S602F Bronco II 89 3.45 7.5 NL - -
S602G Bronco II 89 3.45 7.5 NL - -
S602H Bronco II 90 3.45 7.5 NL - -
S604B Bronco II, Ranger 84-85 3.45 7.5 NL 28 -
S604C Bronco II 86 3.73 7.5 NL - -
S604D Bronco II 87-88 3.73 7.5 NL - -
S604F Bronco II 89 3.73 7.5 NL - -
S604G Bronco II 89 3.73 7.5 NL - -
S604H Bronco II 90 3.73 7.5 NL - -
S605B Bronco II, Ranger 84-85 3.45 7.5 NL 28 -
S605C Bronco II 86 3.73 7.5 L - -
S605D Bronco II 87-88 3.73 7.5 L - -
S605F Bronco II, Ranger 89-90 3.73 7.5 L 28 -
S605G Bronco II, Ranger 89-90 3.73 7.5 L 28 -
S605H Bronco II, Ranger 90-92 3.73 7.5 L 28 -
S606B Bronco II, Ranger 85-86 4.10 7.5 NL 28 -
S607B Bronco II 85 4.10 7.5 L - -
S607C Bronco II 86 4.10 7.5 L - -
S607D Bronco II 87-88 4.10 7.5 L - -
S607-F Bronco II 89 4.10 7.5 L - -
S607G Bronco II, Ranger 89-90 4.10 7.5 L 28 -
S610A Explorer 91-01 3.27 8.8 NL - -
S610B Explorer 91-01 3.27 8.8 NL - -
S610E Explorer 95-01
Mountaineer 99 3.27 8.8 NL - -
S611A Explorer 95-97 3.27 8.8 L - -
S611B Explorer 95-97 3.27 8.8 L - -
S612A Explorer 91-01 3.55 8.8 NL -
S612B Explorer 91-01 3.55 8.8 NL - -
S612E Explorer 95-01
Mountaineer 99 3.55 8.8 NL - -
S613A Explorer 95-01 3.73 8.8 L - -
S613B Explorer 95-01 3.73 8.8 L - -
S613C Explorer 95-01 3.73 8.8 L - -
S613E Explorer 95-01
Explorer 01 Postal
Mountaineer 99-01 3.73 8.8 L - -
S614A Explorer 91-01 3.73 8.8 NL - -
S614B Explorer 91-01
Mountaineer 98-01 3.73 8.8 NL - -
S614E Explorer 95-01
S615B Explorer 95-01 4.10 8.8 L - -
S615C Explorer 95-01 4.10 8.8 L - -
S615E Explorer 95-01
Mountaineer 99-01 4.10 8.8 L - -
S616B Explorer 91-01 4.10 8.8 NL - -
S616E Explorer 96-01
Mountaineer 99-01 4.10 8.8 NL - -
S618A Explorer 98-01
S618E Explorer 98-01
S619A Explorer 96-97 3.73 8.8 L - -
S621A Explorer 96-01
Mountaineer 97-01 3.73 8.8 L - -
S621E Explorer 96-01
S622B Explorer 91-93
Mazda Navajo 91-93 3.27 8.8 NL - -
S622D Explorer 91-94 3.27 8.8 NL - -
S622E Explorer 91-94 3.27 8.8 NL - -
S623A Explorer 00-01 3.55 8.8 L - -
S624B Explorer 91-93
Mazda Navajo 91-93 3.08 8.8 NL - -
S624D Explorer 91-94 3.08 8.8 NL - -
S624E Explorer 91-94 3.08 8.8 NL - -
S625A Explorer 91-94 3.27 8.8 L - -
S625B Explorer 91-94 3.27 8.8 L - -
S626B Explorer 91-93
Mazda Navajo 91-93 3.55 8.8 NL - -
S627A Explorer 95-01
S628A Explorer 91-94 3.73 8.8 NL - -
S628B Explorer 91-94 3.73 8.8 NL - -
S629B Explorer 91-94
Mazda Navajo 91-93 3.73 8.8 L - -
S629D Explorer 91-94 3.73 8.8 L - -
S629A Explorer 91-94 3.27 8.8 L - -
S630A Explorer 00-01
Mountaineer 00-01 3.55 8.8 NL - -
S652A Aerostar 86-87 3.45 7.5 NL - -
S654A Aerostar 86-87 3.73 7.5 NL - -
S656A Aerostar 86-88 3.45 7.5 NL - -
S657A Aerostar 88-90 3.45 7.5 L - -
S658A Aerostar 86-88 3.73 7.5 NL - -
S659A Aerostar 86-88 3.73 7.5 L - -
S660A Aerostar 86 4.10 7.5 NL - -
S661A Aerostar 86-88 4.10 7.5 L - -
S665A Aerostar 89 3.73 7.5 L - -
S666A Aerostar 89 3.73 7.5 NL - -
S667A Aerostar 89-92 4.10 7.5 L 28 -
S668A Aerostar 90-97 4.10 7.5 NL - -
S668C Aerostar 90-97 4.10 7.5 NL - -
S668H Aerostar 90-97 4.10 7.5 NL - -
or
L Axle
Shaft
Splines Additional
Information
Ratio Diameter
of RG
Explorer 01 Postal
hail destroyer
02-15-2018 06:06 PM
Cowboy34
06-21-2010 11:41 AM
