I have a 2002 F-350 SRW 7.3L CC LB. I have a slight Vibration at about 40 MPH and then when I get up to 65 I get a hum sound kind of like mud tires. I have pathfinder tires. Not sure if this is normal or not.
With the vibrations around that speed, have you checked for wheel bearings? Jack the vehicle up and try to wiggle the tire, see if theres any play. Also possibly, a brake caliper hanging up, see if the wheels spin freely. Just 2 drops in a bucket, but may get you started narrowing down the issue.
Ok I jacked up the front of the truck and the driver side had a slight bit of movement in it, none in the passenger side. Both wheels feel like they have a brake pad hanging up a little. If you give it a spin it will go a little bit and then come to a stop. Is there any adjustment in the bearing, or is it just a replace it thing. Also with the passenger side not spinning real free does it just need greased maybe or replaced also. If I take this apart what parts will I need to get to put it back together.
Okay, I got the two Wheel bearing hubs assemblies ordered. I have manual hubs. Is there anything else I should replace while I have it apart or anything I will need to have. I plan to pick up the new studs that hold on the wheel bearings.
