mildew smell from the AC - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 05-14-2001, 09:07 AM
millersnva1 millersnva1 is offline
millersnva1 is starting off with a positive reputation.
The AC smells like mildew in my 97 Exp. Any ideas on how to get rid of it?
Old 05-14-2001, 10:15 PM
jakegypsum's Avatar
jakegypsum jakegypsum is offline
jakegypsum is starting off with a positive reputation.
My AC stinks bad! The Ford EXPI manual says not to turn the AC controls to the "OFF" position. Turning off the ths system traps moisture inside thus causing the bad smell from stagnant water. There was also something posted on one of these boards last summer about this problem.
Now, my problem is that I have been following this proceedure and it worked fine all last summer but now as the weather is getting warmer, the smell has crept back in. I have followed the proceedure but the stink is there and it is bad. Anybody know where the drainage tube is? I have not noticed any condensation being drained out. I believe that the post from last year said somthing to the effect that the drain port/hose is very tough to locate.
Anybody have any ideas?
Jakegypsum // Ford fleet, soup to nuts.
Old 05-27-2001, 08:43 PM
SHANE_2 SHANE_2 is offline
SHANE_2 is starting off with a positive reputation.
Take it to your local Ford dealer. We have chemicals that are made for just that. And they do work trust me I work at a Ford dealer and I've also used them on my truck.
Old 05-28-2001, 12:03 AM
jakegypsum's Avatar
Shane, I did take my 99' Expi to the dealer last tuesday and they did clear the problem. They unplugged the drainage port and they did use the chemicals to freshen the air. My AC runs like the way it should now. Like new. They did a very good job and it was covered by warranty.
Any ideas on how to keep the drain port from plugging up? I have followed the instructions in the owners manual. I am concirned that this may happen again. Thanks. Jake.
Old 07-18-2001, 09:08 PM
jakegypsum's Avatar
Old 12-21-2001, 08:59 PM
wwest wwest is offline
wwest is starting off with a positive reputation.
Basically because NipponDenso engineers are some kind of idiots.
Shortly after A/C became common in automobiles some bright young engineer realized that in the process of the A/C cooling the incoming airflow it oftentimes also dehumidified it. And that of course helps prevent and remove condensation from the interior windshield surface. So from that time on, until about the mid-eighties, it became pretty standard to use the A/C, supplemented by lots of heat, whenever the defrost/defog/demist function was activated at least as long as the A/C was functionally effective, usually only above about 50 degrees F.
Then some idiot decided that if a little bit of something was good then a LOT would be excellent!
NOT!!!
If you wish to use the A/C below 50F (when the RH is usually below 50% anyway, with a few regional exceptions)to dehumidify the airflow then the system must become SUPER EFFICIENT.
The A/C evaporator, the device that does ALL the work, cooling and dehumidifying, cannot be chilled below freezing. So that leaves very few ways to increase its efficiency, my 92 LS400 evaporator is extremely dense and complex, over 10,000 square inches of surface area. The longer the air molecules take to move through the evaporator the colder they become, so in order for the system to work the airflow must be very low.
The entire Lexus product line uses the A/C system EXCLUSIVELY to help prevent and remove condensation from the interior surface of the windshield in defrost/defog/demist mode, a system which is entirely NON-FUNCTIONAL for this purpose with outside temperatures near, at, or below freezing.
So if you hear of someone inexplicably leaving the roadbed and being killed on a snowy and cold day driving a Lexus or Toyota think about this. Maybe s/he lost sight of the roadbed because his/her windshield fogged over virtually instantaneously.
And now along comes toxic mold to further muddy up the issue. Prior to the mid-eighties there was no reason to run an A/C below about 50F, so heat was used exclusively heat the windshield and evaporate condensation from its surface and to lower the relative humidity.
Above these (50F) ambient temperatures when the A/C was used what moisture that was condensed onto the evaporator vanes but didn't run out the drain tube would evaporate away fairly quickly and not cause a problem.
Remember that extremely dense and complex A/C evaporator in my 92 LS400? It came from the factory coated with a porous nylon film into which was embedded an ant-microbial substance.
In the summer of 1991 Lexus already knew that their use of the A/C in already cool climates for these purposes was creating an environment, cool, damp, dank, that encouraged mold and mildew growth.
Look around on the internet at just how many products that have been developed in the last ten years or so to combat the "gym sock syndrome", the mold and mildew smell we all now have to live with because some idiot engineer decided to try a new gimmick.
Remove you A/C compressor relay when the ambient temperature fall below an average of 50F. And turn up the system heat when you activate defrost/defog/demist mode. The response you get for removing condensation from the interior surface of the windshield will be one damnsight quicker than the A/C can EVER be, and it will continue to work that way all the way down to sub-freezing levels.
AND you won't have to worry about toxic mold.
mildew smell in vents bigredneck47240 2004 - 2008 F150 5 01-28-2010 12:57 PM
Mildew smell!!! Betta Explorer, Sport Trac, Mountaineer & Aviator 2 04-16-2006 05:28 PM
Mildew smell from A/C? azzy522 1999 to 2016 Super Duty 10 12-08-2004 10:52 AM
Foul smelling AC mikester Cooling, Heating, Ventilation & A/C 5 10-12-2002 09:00 AM
mold/mildew smell from AC slumlordcjrd 1999 - 2003 7.3L Power Stroke Diesel 4 06-26-2002 08:38 AM
Tags
2006, ac, bad, expedition, f150, ford, interior, mildew, mold, remove, smell, smells, stinks, stinkswhy, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
