Will a C6 bolt up to a 302? - Ford Truck Enthusiasts Forums
Old 07-14-2010, 02:16 PM
GreatNorthWoods's Avatar
GreatNorthWoods GreatNorthWoods is offline
GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.
Does anyone know if a C6 that was removed from a 460 will bolt to a 302? The 302 currently has an AOD attached...
Old 07-14-2010, 02:22 PM
Fomoko1's Avatar
Fomoko1 Fomoko1 is offline
Fomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputation
These are rare but afew 302 Ford vans did have C6`s.
Old 07-14-2010, 02:27 PM
tacson's Avatar
tacson tacson is offline
tacson has a very good reputation on FTE.tacson has a very good reputation on FTE.tacson has a very good reputation on FTE.
It wont. In FORD transmissions you have big block and small block bellhousings. IF the C6 came from a 460 it will not bolt up to a 302 unless you have something rare that I am not aware of
Old 07-14-2010, 02:37 PM
Quote:
Okay, I was hoping the AOD had the same pattern as a big block bell housing and that it might bolt up. I assume then that only a C4 or FMX will bolt on to my 302 in place of the AOD...
Old 07-14-2010, 02:40 PM
joedellcarter's Avatar
joedellcarter joedellcarter is offline
joedellcarter is starting off with a positive reputation.
I have heard of a few small blocks bolted up to a C6...not sure what they did to acheive that, but either way...you'd get a ton of parasitic loss by bolting that combination together.
Old 07-14-2010, 02:48 PM
Quote:
Yeah, I was aware of that but was willing to forgo the loss of power. The C6 was a heck of a deal....completely rebuilt for 300 bucks!
Old 07-14-2010, 05:17 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Quote:
I'm not sure what you're trying to say here. The bolt pattern you're trying to match is on the back of the block, not the transmission, and with the right combination of parts, the AOD will work behind small or big block engines.
AOD's have a detachable bellhousing where the C-6 case is all one piece, so therefore, if you want to put a C-6 behind a small block, you need a small block C-6. They are out there, and tend to go for quite a bit of money because people seem to think they need one.
Why would you not want to use the AOD? What do you hope to gain by being rid of the overdrive? Most folks these days think having OD is a plus.
Old 07-14-2010, 05:22 PM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
a smallblock C6 will bolt up to the 302 as will a C4..
the big block C6 of course will not.. always wanted and AOD for the 460 instead of having to go all the way to the E40D
Sam
Old 07-14-2010, 05:35 PM
tacson's Avatar
__________________
52 Merc
Just curious in what years and vehicles was the AOD with a detachable bellhousing available? I remember the FMX having a detachable one which is what the AOD was partially derived from. That detachable bellhousing version of the AOD sounds interesting...
Old 07-14-2010, 05:38 PM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
Aftermarket AOD will have a 460 bolt pattern bellhousing....not cheap!
C6 with small bolt pattern can be found, but usually in 4x4 tail housing form. Can switch the tail housing and tailshaft to 2wd, though. (I have a 4x4 version behind my 300 6 in my '79 Bronco)
C6 is a one piece case, as is the AOD.
C4 will have a removeable bell housing and are usually in the small block bolt pattern, though some big block (460) bolt pattern bells can be found.
If you are having trouble adjusting the AOD, or it's already toast, and you must go into "rebuild mode", then I would still use the AOD for a small block engine. Dollar for dollar, it's going to net you the best return in the end. My 2 cents.
Old 07-14-2010, 06:10 PM
sdetweil's Avatar
Quote:
never seen one listed anywhere.. I've seen adapter plates,
like $700... actually 795 now
http://www.transmissionadapters.com/Pricing.htm
Sam
Old 07-14-2010, 06:31 PM
312 312 is offline
312 is starting off with a positive reputation.
the AOD is one piece.
Old 07-14-2010, 07:10 PM
havi's Avatar
Transmission Adapter Pricing
Sam
Yes adapter plates....
I was thinking of the Lentech AOD, but they use a JW Ultrabell, after the original bell is cut off the trans.
Dynamic Racing Transmissions, LLC - Torque Converter Techniques can build the Lentech strip terminator....again not cheap, lol. Not sure if this site is still working, but a fella over on the fox tbird forum I frequent had one for sale last year.
Old 07-14-2010, 09:15 PM
olebob4950's Avatar
olebob4950 olebob4950 is offline
olebob4950 is starting off with a positive reputation.
Small Block C6
I have a c6 behind a 351 w 1977 van.
Bob
Old 07-15-2010, 08:32 AM
Perhaps I didn't say it as well as I could have but what I was asking is if the AOD fits the block then would the C6. The AOD I have is questionable as to condition and did not want to install it and then have to pull it back out. It also does NOT have a detachable bell housing. It is a one piece case. It wasn't so much the idea of getting rid of the overdrive as putting in a transmission that I know is good the first time and not having to do it over. I'll also be running a 3:08 rear gear which is a bit tall for an AOD. I ran a 3:00 gear with a 700-R4 in a previous project and it didn't shift into OD until about 55 MPH. I can live with that, however, so if the AOD is good I'll be happy with it.
302 or 351 flywheel tommygirl Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 10-29-2013 05:53 PM
302 with c6??? Possible?? 52' fordnut 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 30 01-14-2013 10:05 AM
1959 ford 302 motor mounts rodriguezfords 1957 - 1960 F100 & Larger F-Series Trucks 4 10-26-2012 05:59 PM
302/ transmission interchange roosplash Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 05-28-2012 09:14 PM
302...c4 or c6 sedly 1973 - 1979 F-100 & Larger F-Series Trucks 5 02-03-2009 01:35 PM
Tags
1973, 300, 302, bell, blocks, bolt, bronco, c6, early, engines, ford, housing, install, newer, put, sbf, small, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
