302 and c4
you'll have to get a new cable I believe. I used a 60" for my toploader but it was close. they do have an 80" also I got mine off ebay a regular tranny place. make sure you get the correct ends that's all. you may also need a speedo gear if you c4 doesn;t have one. I think it was $36ish shipped
bob
bob
302 C4 speedo cable
Exact replacement with gear change is avaible from Sacremento Vintage Ford 888-367-100 or www.vintageford.com
on
Go to your local partshouse and look at a 1970 F-150 (or is that F-100???) speedometer cable and housing. If the 52 speedometer takes a 5/8 nut and the transmission end just slides in with a keeper bracket it should work. I'm using one for my AOD and Dolphin mechanical speedometer...
on
From what I've seen they are pretty much the same where they go into the transmission. The difference is where it connects to the speedometer. After a certain year they went to a clip on instead of a screw on at the speedometer head. The one I got was originally for a C4 or C6 but it fits my AOD...
BlackLabel78
06-01-2009 12:30 AM
fordguy76
04-16-2007 05:26 AM
