2000 F-150 5.4 Coolant Leak at Water Crossover - Ford Truck Enthusiasts Forums
Old 07-13-2010, 11:27 PM
kenstub kenstub is offline
kenstub is starting off with a positive reputation.
Hello.. I've got a 2000 f-150 5.4 L with 260,000 miles. It is leaking coolant at the water crossover. Cant get bolt out to take crossover off the intake. Think its actually isntalled on the manifold before manilfold goes into engine. Intake manifold has to be replaced. Anyone done this? I've done just about everything so I'm pretty confident I can do it. Already ordered the parts (upper intake with gaskets), and 16 new o-rings for the fuel injectors. Before I tear my truck to pieces I wanted to get some input. Is this a hard job? Do you guys recommend doing the lower intake as well? Thanks
Old 07-14-2010, 09:23 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
i had the same thing. yes, the crossover is bolted to the bottom. mine had the manifold edges break around the hole and let the o-ring gasket fail. i have a few photos in a past post i will put up. I think i took it off in 3-4 hours one saturday.. did some repairs and other work.. then put it back together on sunday in 3-4 hours..
Old 07-14-2010, 09:24 PM
steve(ill)'s Avatar
Old 07-14-2010, 09:27 PM
steve(ill)'s Avatar
make sure you double check the tubes in the valley below the manifold--- might want to change out just for the H of it.
Old 07-28-2010, 12:44 AM
Thanks.. I actually already saw your pic's.. Great job doing that. It inspired me to do it myself. Will check the tubes.
Coolant Crossover Tube/Intake Manifold leak and replacement timbersteel Expedition & Navigator 17 08-21-2013 04:15 PM
5.4 Coolant Leak Ron Mantz Modular V8 (4.6L, 5.4L) 2 12-29-2010 08:39 AM
coolant crossover tube leaking psd77066 Expedition & Navigator 5 09-07-2009 08:46 PM
5.4 coolant leak at the intake Superdave Modular V8 (4.6L, 5.4L) 4 06-11-2009 09:25 PM
5.4 coolant leak at the intake Superdave 1999 to 2016 Super Duty 13 06-10-2009 02:34 AM
Tags
2000, 54, antifreeze, coolant, cross, crossover, expedition, f150, f250, ford, gaskets, intake, leak, leaks, manifold, replace
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
