Door Chime - Ford Truck Enthusiasts Forums
Door Chime
Old 07-13-2010, 11:15 PM
Tomahawk's Avatar
Tomahawk Tomahawk is offline
Tomahawk has a superb reputationTomahawk has a superb reputationTomahawk has a superb reputationTomahawk has a superb reputationTomahawk has a superb reputationTomahawk has a superb reputationTomahawk has a superb reputationTomahawk has a superb reputationTomahawk has a superb reputationTomahawk has a superb reputationTomahawk has a superb reputation
Door Chime
Stop the door chime when your keys are in the ignition switch on the 2011 Super Duty.
1. Remove the 3 screws that attach the bottom half of the steering column cover. You will need a 5.5mm or 7/32" socket to remove them.
2. The connector is located about 3" below and 2" in front of the turn signal lever, unclip the latch and remove the connector.
3. Pry the red lock out of the connector, this will allow you to bend the locking tab, and remove the blue wire. The blue wire is located between the violet/blue wire and blue/violet wire. The blue wire is also a smaller gauge than the other 5 wires.
4. Put a piece of heat shrink or electrical tape over the end of the blue wire, snap the red lock back in place, plug the connector back in and replace the steering column cover.
5. Enjoy the silence and remember your key pad unlock code.
Old 07-13-2010, 11:21 PM
EpicCowlick's Avatar
EpicCowlick EpicCowlick is offline
EpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud of
Tomahawk - that's awesome. I count on the little chime though cause I'd leave the keys in the ignition all the time without it...
Old 07-13-2010, 11:40 PM
Huntingbigun's Avatar
Huntingbigun Huntingbigun is offline
Huntingbigun is starting off with a positive reputation.
Cool any ideas on the back up camera to make it on demand?
Old 07-14-2010, 12:45 AM
my996duc1's Avatar
my996duc1 my996duc1 is offline
my996duc1 is gaining momentum as a positive member of FTE.my996duc1 is gaining momentum as a positive member of FTE.
Quote:
Obviously a pulled wire would be ideal but I sent this company an email a few weeks ago and they said to check back in a month for our application.
This unlocks a few features on other models such as DVD, NAV, and camera(s). It also allows a person to add multiple cameras.
FORD LOCKPICKS
Old 07-14-2010, 10:07 AM
rickatic rickatic is offline
rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.
The only annoyance so far on my new truck is when I put the tailgate down to back under the fifth wheel the back up camera loses it's mind. I know you just disable it from the info center but it still annoys me. If this is my biggest complaint I should just keep quiet. I have the AutoEnginuity software package but I have not hooked it up yet to see what it can do.
Old 07-14-2010, 10:35 AM
Quote:
Hey Rick - Keep quiet, will ya? Some of us have serious issues with the truck to discuss. For example, mine accumulates too many miles too quickly and it gets dirty really fast. Give us some space, sheeze... (sarc)
Old 07-14-2010, 12:51 PM
Maybe I will go over to the Dodge Boys forums...
Old 08-12-2010, 09:16 AM
ruschejj's Avatar
ruschejj ruschejj is offline
ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.
10 minutes and done. Thanks Tomohawk.
Looking forward to the ways to unlock the nav while driving, DVD while driving. Passengers get a raw deal and so do I not being able to have someone else input nav destinations while I am driving.
Old 08-12-2010, 12:50 PM
Rafiki2cu Rafiki2cu is offline
Rafiki2cu is starting off with a positive reputation.
Now you better leave the dodge boys alone, the last time I read the rv forum I thought you were going to give them a heart attack.
Old 08-12-2010, 03:04 PM
The Dodge boys over there are a very insecure bunch. Any other brand post brings them out in droves. They must be suicidal today after hearing Ford made 2.6 billion and GM made 130 billion and Chrysler lost 170 million. I guess if I had a well respected engine I would crow but they ultimately must realize the truck wrapped around it is a POS. They get impatient with me because I fight back with facts and personal experience. They fight with anecdotal and wrong information. I will admit that it is getting old.
Regards
Old 08-12-2010, 11:13 PM
rdenis's Avatar
rdenis rdenis is offline
rdenis is gaining momentum as a positive member of FTE.
Hey Ricatic - did you ever try hooking up your AE to see what's available?
Old 08-14-2010, 11:37 PM
FORDTUF1's Avatar
FORDTUF1 FORDTUF1 is offline
FORDTUF1 is gaining momentum as a positive member of FTE.
Thanks for the info!! now what I have to do is find out how to bypass the seatbelt one. Previous ones you could just push in the red release button, not anymore. I ALWAYS wear it while driving but around the yard, field, messing around it sure is annoying.
When I hook my 5th wheel I just get a real close up view of my bumper and license plate, but it still is working.
Old 08-15-2010, 12:15 PM
bnmccoy's Avatar
bnmccoy bnmccoy is offline
bnmccoy is gaining momentum as a positive member of FTE.bnmccoy is gaining momentum as a positive member of FTE.
Would be nice if Ford would add a second camera for the goosenecks and fifth wheel hitching. At least you guys get your camera video on your Nav unit; I have the Navigation but my backup camera is in the mirror. But I do have the hack for my Nav while driving although it does nothing for Sirius menu..... And no DVD video playing in my model.
I can't see my hitch in bed as the fold-a-cover blocks my view.....
Bob
Old 08-20-2010, 10:27 PM
Rick Cargo's Avatar
Rick Cargo Rick Cargo is offline
Rick Cargo is gaining momentum as a positive member of FTE.
I would be very nice just to eliminate the stupid chime altogether!
Old 08-24-2010, 08:58 PM
skylinekw's Avatar
skylinekw skylinekw is offline
skylinekw is starting off with a positive reputation.
Nothing like peace and quite thanks, this helped out alot. I always leave my key in the ignition and the keyless entry button in my pocket. No more chiming! I was surprised that if you shut the truck off with the key in the ignition and the lights on it still chimes, wich is good. Good instructions, it took no time at all.
2.5kW inverter, RF equipment, Rack install (Note: Many images to load) TRENT310 1999 to 2016 Super Duty 13 10-26-2014 03:46 AM
The poor man's F-350 leveling kit. Tomahawk 6.7L Power Stroke Diesel 45 10-21-2011 12:07 PM
What kind do you put in your Super Duty... Tomahawk 6.7L Power Stroke Diesel 22 10-19-2011 11:02 PM
5th Wheel Hitch with Bed Mat Tomahawk 6.7L Power Stroke Diesel 9 08-28-2010 08:10 PM
2008 model key in ignition chime killer sawtooth 1999 to 2016 Super Duty 22 05-19-2009 12:01 PM
Tags
150, 2003, 2010, 2011, chime, chimes, disable, disabling, door, driver, duty, f150, f250, ford, silence, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
