Door Chime
#46
#47
#49
Turn off Safety-Belt Chime
The driver and front passenger Belt-Minder feature can be deactivated by performing the following procedure.
Before following the procedure, make sure that:
* The parking brake is set
* The gearshift is in P (Park)
* The ignition switch is in the off position
* The driver and front passenger safety belts are unbuckled
1. Turn the ignition switch to the on position. Do not start the engine.
2. Wait until the safety belt warning light turns off. (approximately 1 minute)
* Step 3 must be completed within 30 seconds after the safety belts warning light turns off.
3. For the seating position being disabled, buckle then unbuckle the safety belt 3 times, ending in the unbuckled state.
* After step 3, the restraint system warning light (airbag light) will be turned on for 3 seconds.
4. Within approximately 7 seconds of the light turning off, buckle then unbuckle the safety belt.
* This will disable the Belt-Minder feature for that seat position if it is currently enabled. As confirmed, the restraint system warning light will flash four times per second for 3 seconds.
#50
Kill open door chime with key on
I replaced my 08 in June. Drove home and pulled the ignition switch, dug a bit further and found the switch behind it which activates the key in ignition chime. Similar to what I've done on previous trucks, but a bit trickier. Disconnecting the blue wire is much easier. Adding auxiliary backup lights today and the door open chime got on my nerves. Trying to listen to the radio while wiring the upfitter switch to the pass thru wire. So I hit the computer and found this thread, killed the blue wire and the chime is still going when the door is open with the key in accessory position. Bad call by Ford. It could at least time out after a few seconds. I found the post about grounding the green and purple wire but as my voltage tester kept both the green and red lights glowing whether the door was open or closed I assumed that was not the route to go. I pulled the door cover and found the switch on the latch. Yes, it has a green and purple wire, and a black one. Jumping these two kills the chime. It also disables the interior light and the radio continues to play after you open the door. It looks like a switch is in order.
#51
#52
on
I'm assuming that was mentioned earlier in this thread.
I thought of a wire modification but I remembered the other things depend on sensors to work, like the accessory delay as you mentioned.
#54
Door open chime
I wired a switch in line to jumper the two wires on the door latch sensor. It is the rear (and of course more difficult to reach) of the two plugs on the latch inside the door. I'll post a couple pics later. a simple rocker cut into the underside of the armrest. Looks great and works perfectly. Just flip the switch to kill the door open chime with the key in the accessory position. Flip it back to restore interior lights etc. I also wired an upfitter switch to activate the fog lights, but that belongs in another thread.
#58
help with the locking tab?
Having some issues on the final step. I've removed the red lock out of the connector but am having issues bending the locking tab... anyone have a more detailed description on how to go about it? I've been poking and prodding in there but if I **** it up I'm assuming the process can never be reversed. What exactly does the locking tab look like? which way do I have to bend it? once bent correctly does the wire pull out easy?
#59
#60
Iski123-the metal tab is not the part you need to "bend". I used a very small flat blamed screwdriver that would fit into the connector( the end opposite the end the wires come into) to press on the plastic tab inside the connector. Use a bright flashlight (and in my case a good pair of glasses) and you can see the tab. Press against it and the wire pulls out easily. Hope this helps.
ruschejj-yep, same wire color as shown earlier in the post. Works great.
