Please need HELP!!!!
Hello to all, My name is Mark and i have a 2003 f550 6.0 bucket truck. I am in need of wheel extenders or adaptors to fit my truck on the front only. I am installing new oem factory fender flares and want my tires to stick out more. PLEASE I NEED HELP I CAN NOT FIND ANYTHING FOR MY TRUCK and already purchased the fender flares and can not return. Thanks to all!!! This is a great site!!!!!!!!!
Lug Nuts Wheel Adapters Wheel Spacers Lug Bolts
wheel spacers items - Get great deals on Parts Accessories, wheel adapters items on eBay Motors!
Pricing
I paid around $325 for just the flares no mud flap no front bumper flares those where extra but they are the ford ones big they come wth 19 clips to drill but i took the snap on clips out and used 2 sided tape with the standard holes and the are tough everybody thinks i got i knew truck!
You should already have a set of adapters that act as front spacers on your truck, probably something like the 8 on 170mm to 8 on 200mm spacers 05+ trucks use, but I don't know your exact bolt pattern. I read that 2003 F550s have a 10 on 225mm but you said it's got 8 lugs and I can't see it, so I'll believe you.
The main reason you can't find anything it because running spacers on a truck that probably tops 10,000# is a pretty bad idea for a lot of reasons. The second reason you can't find anything is because getting spacers that are made of steel with the correct bolt pattern is going to be expensive, custom job, because there's probably not a huge market for wheel spacers for 99-04 Ford F4550/550s.
Wheel spacers on a heavy truck can cause a bad wobble in the front end, and will cause the front suspension components to wear out faster. The heavier the truck, the faster the ball joints and bearings fail. Think of it like holding a 50# dumbbell in each hand, lift them up and hold them right over your shoulders and it's no big deal, but try extending your arms and holding them parallel to the floor. Unless you're Arnold circa 1980 you'll notice a difference. Same thing with the truck, but instead of 50# over a foot and a half it's 2500# over 2".
Give these people a call, they may be able to make a custom set of wheel adapters for you.
http://adaptitusa.com/index.aspx
OR
Insted of wheel spacers, if you cant find them, look at a different type/style of rims that will space the tire out more, Just my 2 cents worth
OR
Thank You
A-DAPT-IT USA Wheel Adapters
OR
OR
I will try giving them a call and i will look into some rims also. Thanks !!!!
This is the best site!!!!!
reddogracing
1983 - 2012 Ranger & B-Series
07-05-2004 01:46 PM
