1989 F Super Duty - Ford Truck Enthusiasts Forums
1989 F Super Duty
Old 07-13-2010, 08:50 AM
dbol021 dbol021 is offline
dbol021 is starting off with a positive reputation.
1989 F Super Duty
I am looking to buy a 1989 F Super Duty 7.3 Utility body, Does any one know the specs on this truck or where I can find them. mainly interested in the towing capacity. Thankyou
Old 07-13-2010, 10:39 AM
wreckinball's Avatar
wreckinball wreckinball is offline
wreckinball is gaining momentum as a positive member of FTE.
The "F-Super Duty" (as the fender emblems stated) models appeared from 1987 to 1997. They were basically F-450s built as an "incomplete vehicle" (chassis cab) due to the fact that there was no bed installed and an aftermarket bed (specific to its future use) was added after the truck's initial build date. It came with dual fuel tanks with a dash-mounted toggle switch to switch between each tank while using only the one fuel gauge. It came with a PTO (Power Take-Off) used to power attachments (like winches or a dump bed) from the transmission. They were rated at about 15,000 lb (6,800 kg) GVWR (Gross Vehicle Weight Rating). They came with either the standard 7.5 L (460 CID) gas V8 or the optional 7.3 L (445 CID) diesel V8. All wheels were 10-lug with DRW (Dual Rear Wheels). This model should not be confused with the "Super Duty" commercial line of trucks starting with the 1999 model year.
From wiki on "Ford F Series"
Old 07-13-2010, 11:08 AM
Wow ok that helps do you have any idea what the towing capacity is for a trailer with that truck
Old 07-13-2010, 11:50 AM
can you get the vin? axle type and trans?
Old 07-13-2010, 12:01 PM
greywynd greywynd is offline
greywynd is starting off with a positive reputation.
If it's a superduty, it will have that huge rear axle with disc brakes that they came with. Most are geared 4.11 or lower (there was a 5.XX ratio too I think). They aren't fast trucks, but especially with a ZF5 in them, would likely move a small house if needed. As to actual towing numbers, we'd need some more info on it, rear axle ratio, tranny, etc.
There's a newer user on here now moving a PC50 excavator with one, which is going to be about a 5 tonne machine, plus his float, so likely in the 16-20K pound range to tow?
Old 07-13-2010, 12:04 PM
i know the weight will be huge but the vin will give me an exact number so he can know for sure.
Old 07-13-2010, 12:17 PM
oreocreaming's Avatar
oreocreaming oreocreaming is offline
oreocreaming is gaining momentum as a positive member of FTE.
guy next door as a 89. its got the zf5 in it, he had 5.xx (cant remember the exact 5.38 i think) and he was maxxed out on the red line at 60mph. he got a set of 4.56 for them (thats the tallest gears they have for them) they are disk rear as stated before, they also have hydroboost brake booster and the transmission is the 4x4 version. their parking brake unit bolts to the rear of the transmission where the transfer case would be. if nobody answers you by the time i talk to him next, i will ask what his gcvwr is.
Old 07-13-2010, 01:29 PM
Sounds good I will try to get the vin and post it when I do, thanks for all the help so far
Old 07-13-2010, 05:50 PM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
the vin should start with 1FTMF47M
this is for a F superduty 4X2 with a diesel engine. GVWR 16,001-19,500 lb
if the vin is F47L, than the GVWR is going to be 14,001-16000 lbs
Old 07-14-2010, 03:34 PM
ok finally got the vin 2FDLF47MoKCAo9641
Old 07-14-2010, 03:39 PM
i ain't rite
Quote:
that will give you a GVWR of 16,001-19,500 lb
Old 07-14-2010, 03:43 PM
that is good. you think truck and trailer is close to 26,000 gcvwr
Old 07-16-2010, 09:29 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
That would depend on the trailer.
With a tandem or tri axle trailer running dual wheels on the axles, you could get above 26,000 pounds.
Old 09-11-2011, 08:50 PM
gnarles gnarles is offline
gnarles is starting off with a positive reputation.
Where did you get all those specs. from?
I hear of those cds you can get online.
Does any one know where exactly where to get those?
My old chilton just ticks me off.
Old 09-12-2011, 04:55 AM
i ain't rite
factory service manual has all the info you need.
about the only thing chiltons and haynes manuals are good for is lining the floor of a bird cage.
1989 F-Super Duty Headlight Problems ALedbetter1 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 05-14-2016 07:41 AM
Idi wiring kerrymurphy515 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 14 09-02-2015 05:29 PM
F-250 front spindle/nut size glasstruck 1987 - 1996 F150 & Larger F-Series Trucks 3 08-15-2007 06:46 PM
Stock injector flow rating Tsaven Nava Fuel Injection, Carburetion & Fuel System 3 04-23-2006 12:28 AM
Computer on 1989 F150 garyda Computer Chips & Tuners 2 02-19-2002 11:59 PM
Tags
10, 1989, 20k, 69, 73, duty, ford, fsuperduty, gvw, heavy, idi, lbs, lug, sale, super, superduty, towing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
