4.9 EFI to carb?
A duraspark II ignition module and distributer. Also you don't need to change exgaust manifolds but you should fabricate away to heat the intake manifold where the carb exhaust would heat. The efi exhaust manifold is less restrictive. All of this information can be found in the ford 300 forums on this website.
Honestly the efi system for the 300 isn't half bad. Unless you want to upgrade your cam your set.
If you're looking at doing some crazy stuff with your 4.9 then I suggest instead of sinking money into retrofitting it with carb stuff (Most likely you WILL need to cut/knock a hole in the block for the mechanical fuel pump too I believe, unless you go with an electric one.) that you look at and give Mega Squirt a shot. It is a pretty nice system and you can leave everything fuel injected as well as program it how you want, mild or wild and works with any engine upgrade.
on
coolguy1419
42
09-14-2014 07:32 AM
rangergirl94
15
03-22-2012 06:20 PM
ftrk66
05-06-2011 07:03 PM
