Oil Capacity in 5.4l - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 07-16-1999, 01:00 PM
pls60 pls60 is offline
pls60 is starting off with a positive reputation.
I just had my EB Expy in the shop for a couple of minor things, one being the dip stick showing 1/2 quart low on oil after a 6 quart fill. The dealer told me the 5.4 holds 6 1/2 quarts. Is this true? The book clearly says it holds 6 quarts.
Old 07-24-1999, 07:36 PM
Pastmaster Pastmaster is offline
Pastmaster is starting off with a positive reputation.
Even though the book shows 6, there could be extra in the engine itself and maybe in the filter. You might post this in 97-newer and they could help you out...
Old 08-18-1999, 08:11 PM
1dave 1dave is offline
1dave is starting off with a positive reputation.
because the oil filter is remote ,( mounted behind the bumper), it takes 6 1/2 quarts to get a full reading in the 5.4 or 4.6 engines. the hoses take the the other 1/2 quart of oil.
Old 08-26-1999, 07:40 PM
Ford Tough Ford Tough is offline
Ford Tough is starting off with a positive reputation.
>My mother has a 98 Expedition with the 4.6 and the oil filter is not remote but it is still a half quart low. My 97 5.4 4X4 truck's oil filter is behind the front bumper and it is a half quart low after the six quarts are poured in. We just leave them at six quarts. Are the expeditions you are referring to 4X4? I was thinking that the remote oil filter behind the bumper was for easier access on the 4X4 models since they have the front axle just below, where the oil filter would go.
Old 08-27-1999, 12:50 PM
pierre pierre is offline
pierre is starting off with a positive reputation.
Since my first posting, I talked to the service manager at the Ford dealer. He read from the shop manual that the '99 Expy's take 6.5 quarts when changing the filter. (Why would you NOT change the filter!?). They've moved the filter on the '99's. It comes right off the block. I've also sent an email to the Ford engineers via <a href="http://www.ownerconnection.com/home">http://www.ownerconnection.com/home</a> and got the response that 6 quarts is what the engine holds. Kinda conflicts with the dealer except the dealer couldn't have been more responsive to my problem. (Yes, I'm talking about a Ford dealer!) At any rate, so long as I don't start leaking, I going to use 6.5 quarts on a change.
Old 08-31-1999, 10:30 AM
Greg Greg is offline
Greg is starting off with a positive reputation.
re: oil filter on the block on the 99s
My 99 4x4 5.4L oil filter is still remote, behind the bumper. (And I applaud Ford for this - sure beats dripping oil down the axle, frame, tie rods, and every where else!!!) I've not noticed the dipstick indicating 1/2 qt low, but then I've not looked that close, either..... guess I will tonight!
Greg
Old 09-01-1999, 09:28 PM
obritg obritg is offline
obritg is starting off with a positive reputation.
I also have a 98 Expedition with the 5.4 and remote mounted filter. The remote mount is part of the towing package, since the package includes an oil cooler. This is why some people are reporting filters on the block (non class III towing pkg) and remote mounted (class III pkg)When I had my oil changed at the dealer they charged me for 7 quarts and my dipstick read full, when I change it myself I putin the 6 quarts and it reads a 1/2 quart low. So either the dipstick is not reading properly or the engine really requires 6 and 1/2 quarts.???????Just thought I'd add my 2 cents.
Old 09-21-1999, 11:47 AM
Don Don is offline
Don is starting off with a positive reputation.
I change my own oil on my 99 EXP (5.4L w/tow) and change the filter; I add 6qts of oil and after running the engine,the dip stick shows oil up to the top of the cross-hatched area. The "max" mark is just above that.
Old 09-21-1999, 03:06 PM
My mothers 98 expedition has the towing package and her oil filter on the block.
Old 03-02-2000, 03:41 AM
tng
Guest
Posts: n/a
I hve 98 5.4 expy w tow package and remote filter. It definitely takes 6 1/2 qt to get to max line and 6 qts puts right between min and max. The manual says to not top off if falls in middle probaby because dumb dealers always put in 7 qt and overfill. Sounds like good advice to me.
Old 03-02-2000, 07:28 PM
john john is offline
john is starting off with a positive reputation.
***5.4 with Tow Package/ Always change with six Quarts!( manual-Engine Capacity)/ better a little less than too much!!!!
What's the big deal about a half a quart-get real!your engine can probably run on 3 quarts!!! Don't risk overfill!! it can cause far worse damage in the long run!!
Old 03-03-2000, 12:14 PM
KS KS is offline
KS is starting off with a positive reputation.
The Exp. will take 6 - 7 quarts depending on whether you have the towing package. The tow package includes an oil cooler which takes additional oil.
Old 12-23-2001, 06:23 PM
rem rem is offline
rem is starting off with a positive reputation.
97 with a 5.4 with tow package...takes 7 quarts with a filter change...
Old 12-23-2001, 07:34 PM
redvet redvet is offline
redvet is starting off with a positive reputation.
I have a '99 EB expo 5.4 with the tow package.
The filter is on the side of the engine.
I've always added 6 qts when changing the oil.
I'll admit I never look at the dipstick.
Should I adding 7 qts?
Old 12-26-2001, 11:00 AM
adelyser adelyser is offline
adelyser is starting off with a positive reputation.
My '97 with the towing package also takes 7 quarts with a filter change, and it doesn't indicate overfilled on the dipstick. Make sure to run your Expy and circulate the oil before checking the level as it will lower the level some when it fills the filter and lines.
Aaron D.
5.4 oil capacity fordboy_52 1997 - 2003 F150 24 07-25-2015 07:18 PM
Oil Change capacities 1997 F250 LD 5.4 Liter 97F250LD4X 1997 - 2003 F150 4 12-24-2010 12:48 AM
heres the capacities list for our trucks.... oreocreaming Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 29 07-02-2010 05:12 PM
How many quarts of oil is my pan ? 79 bronco 4x4 Ranger1F150 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 7 07-30-2007 11:42 AM
302 OIL CAPACITY: 6 quarts vs. 5 quarts ????????? BB Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 11-27-2000 07:22 PM
Tags
06, 2001, 2006, 54, 54l, 97, 98, capaci, capacity, engine, expedition, expidition, ford, navigator, oil, quart
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
