Which 8 Lug Wheels will fit a Dent?
Old 07-13-2010, 05:28 AM
Kalve's Avatar
Kalve
Kalve is offline
I have a 74 F250 8 lug an was wanting to know which 8 lugs will fit it? I found some off of a 95 F250 will this work?
Old 07-13-2010, 06:07 AM
dynamic's Avatar
dynamic
dynamic is offline
YUP the rims off the 95 should fit with no problems!
infact any 8 lug up to 1998 Ford should fit, and any 8 lug from chevy and dodge up to current should be the same as well !
You may have some hub clearance issues with certain rims, but anything is fixable with the right tools.
Old 07-13-2010, 09:26 AM
704 dentside man's Avatar
704 dentside man
704 dentside man is offline
I thought 97 was the move to metric bolt patterns? Anyway...you need an 8x6.5 bolt pattern. I can't remember which uses what, but I know between Ford, Dodge, Chevy...that there was a difference between hubcentric and lugcentric rims...so those are the clearance issues mentioned above.
Old 07-13-2010, 10:53 AM
Kalve's Avatar
Kalve
Kalve is offline
So I need to ask an see if the wheels are 8x6.5 bolt pattern an if so they will fit correct? An how do you know if they are the 8x6.5 bolt pattern?
Old 07-13-2010, 11:41 AM
montana_highboy's Avatar
montana_highboy
montana_highboy is offline
I believe Fords change over to the metric bolt pattern was '99 (i could be wrong though).
Old 07-13-2010, 03:10 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Ford used 8 on 6.5 from beginning of time till 97.
Ford went to thee metrick 8 on 170mm in 99(the superduty)
If you noticed there were no such thing as a 8 lug 98
Chevy is 8 on 6.5 bolt pattern but their center huba on a 88 to current are typically small.
Dodge used a 8 on 6.5 patten as well. Their hub center i have never run into an issue.
Aftermarket wheels typicall have a big enough center hub to fit the big 3
Old 07-14-2010, 09:48 AM
Kalve's Avatar
Kalve
Kalve is offline
So these wheels would work with no problem right?
Old 07-14-2010, 09:53 AM
dynamic's Avatar
dynamic
dynamic is offline
SEE SECOND POST!!!!
"YUP the rims off the 95 should fit with no problems!"
Old 07-14-2010, 10:01 AM
Kalve's Avatar
Kalve
Kalve is offline
Ok thanks I will check bout getting them. On the wheels does it matter if they are steel or Alum.? I was told that steel wheels are best for towing & hauling & that Alum. wheels can't handle the weight. A tire store in town told me the Alum. wheels are for looks only an can't handle the weight on a heavy tow or heavy hauling that steel OEM wheels were the best to go.
Old 07-14-2010, 11:11 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
If it's a Ford stock rim, it should be able to handle the weight. If it's aftermarket, who knows.
I once had a heck of a time getting a set of Chevy (or was it Dodge?) rims to fit over the front hubs of my highboy Fun Fun Fun... back to the junkyard I went.
Old 07-14-2010, 11:14 AM
Kalve's Avatar
Kalve
Kalve is offline
its a after market wheel
Old 07-16-2010, 04:12 PM
Diesel_Brad
Most wheels will have a weight rating cast into the wheel
Old 07-16-2010, 05:17 PM
pcskies's Avatar
pcskies
pcskies is offline
The 8 lug 16x7 steel rims I have on my 73 F250 camper special are off of a 2006 Econoline E250 van. Ford never changed the vans to metric.
Old 07-16-2010, 05:25 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
81-F-150-Explorer is offline
Ford wheels changed over time with most notibly how the wheel covers and hub caps attach for example, but the bolt pattern remained the same untill it changed in 1997/1998.
Typically these years are interchangeable 8 Lug on 6.5.
Going from memory...
1948-1952 F-2 and F-3.
1953-1956 F-250 and F-350 (Has clips to hold hub caps)
1957-1996 F-250 and F-350 (Has dimples to hold the hub caps)
1997 F-250HD and F-350
The 1997 F-250 (Non-HD) and 1998 and newer has metric wheels and will not work.
Old 07-16-2010, 05:34 PM
81-F-150-Explorer
This is true, the Econoline Van wheels will work with the F-series.
The last Major Redesign of the Econoline Van was in 1992. It's due again as that was 18 years ago now.
The 1975-1991 Econoline was based on the 1973-1979 pickup design, and lasted 16 years with a lot of swappable parts.
Quick Reply: Which 8 Lug Wheels will fit a Dent?
