Running boards painted
I'm hoping that its durable as well. I'm doing my entire chassis with the roll on bed liner. I figure it should work abit better than the undercoating...
What brand did you use? Duplicolor? How did you prep"
Tardster, what brand are you considering? Herculiner?
I may be able to actually offer some experience on this subject. I Herculinered my entire 1974 suburban once. I Duplicolored my Cummins truck's rocker panels last year, sprayed/rolled several truck beds and i've done various other smaller projects with different brands of bedliner.
The boards look good by the way, I'm planning on doing the same thing to mine as wel.
I'm using the rustoleum brand roll on bed liner from walmart. A gallon of it was 49 bucks and so far it seems to be holding up pretty good. I used it on the inner fenders and dropped one of the other and it didn't scratch it. Now for the actual fenders I will use the spray on undercoating on the inside of those but I wanted something a little stronger for the frame. The weather here in Illinois isn't the greatest so to make sure its lasts a long time.
I don't envy you over there in IL, my wife is from WI and good grief, every car older than 5yrs is a rust bucket over there. I hate road salt!
Received 4,132 Likes
on
Herculiner was what used to be offered at our Canadian Tire store but have switched to EZliner. Both products are manufactured by Dominion Sure Seal. I used the Ezliner on the underside of my panel, it looks as though it will be a very durable product and is easy to spray with a shutz gun. It will be awhile yet before I find just how durable it will be though.
I had thought about using the bed liner on the inside of the fenders myself and I might but it all depends on how much I have leftover, before I start putting her back together I plan on putting 1 more coat on just to make sure I haven't missed any spots. The rustoleum brand I have can either be rolled on or sprayed on I just haven't tried spraying it yet, I was going to try that once I got the bed off and see how big of a differance there between spraying and rolling it on.
