temporary cab stand
Old 07-12-2010, 09:26 PM
sofob0909's Avatar
sofob0909
sofob0909 is offline
temporary cab stand
Hey everyone
Here is my situation.
I have limited space this summer. (working in my parents 2 car garage)
I need your ideas and experience for how to build some sort of wooden temporary frame for the cab so i can roll it around and have it be more accessable. I am going to be working on the frame and doing some body work on the cab so i wanted to mount low to the ground so i can have access to it and be able to sit and work.
I already bent up the bottom of cab sides below the the door frame doing things the way i have them now so i will need to fix this but i want to have some sort of more stable support.
That are your ideas?
Should i just build a wooden dolly that uses the 4 cab mounts?
Thanks.
Stephen
Old 07-12-2010, 09:56 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
I used a 4x5 pallet with 4x6 beams under the front/rear of the cab, and 4x6 beams front to back under the pallet and 4 casters from harbor frieght... I used some allthread to hold it together..
Sam
Old 07-13-2010, 12:15 AM
TomPorter's Avatar
TomPorter
TomPorter is offline
I've used those cheap furniture dollies from home depot with scrap wooden blocks in the right places. Sorry, no photos tho.
Old 07-13-2010, 06:54 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
yep, that works.. I didn't want to get down on the floor all the time to work on the lower sections..
Sam
Old 07-13-2010, 07:59 AM
Lakotas53's Avatar
Lakotas53
Lakotas53 is offline
Mine looks a lot like Sam's. I just used 2 by 4's and built a frame to fit the underside of the cab. Then put some 8 inch swivel casters I had laying around under it. I'm at work right now and can't post pics. Might be a pic in my gallery photos but not sure.
newold46
1947 and Older Ford Trucks
08-16-2016 12:13 PM
Greg5OH
03-30-2016 08:33 PM
kr98664
27
02-07-2016 11:37 PM
specials07
13
06-30-2015 10:16 AM
fordmtnman
Paint & Bodywork
16
07-08-2005 01:52 PM
Quick Reply: temporary cab stand
