Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > North Carolina Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
North Carolina Chapter Join Chapter, Leader:ncheavymetal
  #1 (permalink)
Old 07-12-2010, 08:42 PM
dlocklear11 dlocklear11 is offline
Garage is empty, add now
dlocklear11 is starting off with a positive reputation.
dismantling
I got a 460 out of a lincoln bout a 75 model and wanted to know if its possible to strip off the a/c compressor and the power steering and it still be fine, also my basic question is can i use the same ignition system that is currently on my 68 f100 and fire it up and it run right it is carburated, but was wondering if anyone had done this and what types of issues they ran into, i have the mounts and perches and towers and all to sit it in problem is i want it to run when it does
  #2 (permalink)
Old 07-13-2010, 11:07 AM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
1995 Ford F-350
Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.
It should be fine without the a/c and p/s.
Not sure on the ignition system. If they both run the same kind it should work, but I dont' know if they are both points style or newer... Depends on the distributor mainly.
Is your '68 a 460 also?
__________________
Brownie (Evan) Ooh-Rah! Once a Marine Always a Marine Oregon Chapter Member
'95 F350 CC 4x4 - 7.3 PSD, 190k, Built E4OD, SRW Conv, 4x4 Conv, Rosewood Stage I's, PHP Chip, 6637 Intake, 3" DP, Lost Kitty, 4" Exhaust, 3" RSK, 38 gal rear tank, fuel vent mod, 140v IDM, HPX, FPR Shim, 3.55 gears
'10 Escape, 200hp 3.0 V6, 4x4 - Stock
Tags
dismantling, ford, ranchero, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
