You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
[WTT] : [D60 front and rearTotally rebuilt] [4" Lift kit]& [1992 Toyota Previa] for
A Decent 4x4 that will seat 4 people,
Details of D60's
Dana 60 limited slip rear end fully rebuilt:
Bearings, seals, shoes, rotors and wheel cylanders, turned.
Posi fluid, E brake cables, gasket grease and painted black.
Front end Dana 60 fully rebuilt: above pinion axle
Limited slip, u joints, inner grease seals, v seals, posi fluid, hub lock nuts, hub o rings, gaskets.
Custom steering linkage/tie rods & Leaf springs with hangars to fit 1978/79 1/2 ton bronco or pick up.
Can fit 40"s
This kit bolts right onto your 78/79 Bronco because it came out of a 79 Bronco that was totaled.
My plan was to build up my 78, tub it out and flare it, stick some 40" tires on her
However, I discovered after sitting 8 years in the garage, it rusted out really really bad, I abandoned it 4 years ago, but Ive still got all the parts and have been thinking to start up this project again, unless I can get a decent truck that with start and go to some decent places.
4" Lift kit for 78/79 Bronco with 5 BFG Muds, 35x12.5x15 on white 5 spoke steelies. It is missing one C bushing. Its possible it might be in my garage somewhere, Id have to get motivated to look for it though.
Lots of tread left and spare still has rubber nubs.
