They did do some block strength updates, however I cannot believe that adds up that much ...
I would believe they are all weighed dry, most do weigh dry.
Duh, the 7.3 has larger head bolts. The bolt itself is offset by the larger holes in the block and heads, but the heads of the bolts are larger so weigh more. lol
Oh he is so funny. Myself i figure that since they thinned the cylinder walls, enlarged the holes in the heads and the blockIt would wiegh less. But then again it has better rockers, and I think they deleted some of the water passages at the back so it should just offset the lost wieght.
better rockers wont add the weight.... maybe 5 lbs tops. havent heard they deleted water passages, that would add weight, since your filling voids with cast iron.
lol.no matter how ya look at it.lifting her up in the shade tree,your not going to notice the few lbs difference hey Rick.
is she up and out yet btw?
how long can a person stand being outside in Fla right now anyway,all of 50 seconds at a time lol.
