6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Procedure Fuel Filter Replacement (6.4)
Old 05-18-2015, 06:56 PM
slowmans's Avatar
slowmans
slowmans is offline
I don't get it, I always have a full tank, have changed my 6.4 at least 10 times and more maybe 20 times on my 6.0.....Never ever had a problem with fuel stopping? I always drain separator , pull and install lower filter then do engine mounted filter, cycle key 3-4 times and off I go!
Old 05-19-2015, 05:04 AM
dgeesaman's Avatar
dgeesaman
dgeesaman is offline
I was going to attach a photo of my 3 drain pans half full of diesel but this forum is stone age and doesn't accept attachments.
500 smiley icons, though.
Old 05-19-2015, 09:24 AM
wp6529's Avatar
wp6529
wp6529 is offline
I always open the upper filter first before draining the separator. I believe this allows fuel to drain properly and not continue to flow down as air is allowed up from an open HFCM. At any rate in a dozen or so fuel filter changes I've never had more than about a quart of collected fuel.
Old 08-09-2015, 02:14 PM
Ricau's Avatar
Ricau
Ricau is offline
Ricau
I changed fuel filters on 2010 F350. The fuel never did stop running when I removed the frame filter. I changed the engine filter 1st. The filters are in but can't keep the engine running for more than a few seconds. Then I have to go through the turn key on for 30 seconds six times just to get it to run for a few seconds again. Anybody have any ideas?
Old 08-09-2015, 02:22 PM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
Still have air in the system or the fuel cutoff switch tripped.
Do this: Turn the key to the on position only. Leave it there till you no longer hear the low pressure pump running.
turn key off and repeat.
Ignore the 30 seconds the book says.
Also check your fuel cutoff switch to see if it tripped. It is located on the passenger side of the dash.
Open the passenger door and right on the side of the dash is the door.
Old 08-09-2015, 02:57 PM
Ricau's Avatar
Ricau
Ricau is offline
I turned the key on and off while listening to the fuel pump instead of timing it. I checked the fuel cut-off switch. It didn't seem to be tripped, but I depressed the red button anyway. I started it but it only ran a few seconds and I did the key thing again and it started for only a few seconds again. I have taken about 4-5 gallons out of the drain valve on the frame filter. Probably at least a couple of gallons went on the ground. Could this be why there's so much air?
Old 08-09-2015, 03:36 PM
senix's Avatar
senix
senix is online now
No. You can try to open the scrader valve by the fuel cooler and see if you can get it primed there.
Also pull the fuel filters and verify that they were put on correctly.
Are you using OEM filters?
Old 08-09-2015, 04:26 PM
Ricau's Avatar
Ricau
Ricau is offline
I pulled the filters earlier before I went on this post. I didn't see anyway the filters could go on any other way and work. But if I have to do it again, I will. These filters are not OEM. They came from AutoZone.
I have been doing the key thing for the past hour or so with no change.
Old 08-09-2015, 04:30 PM
senix's Avatar
senix
senix is online now
Put the oem ones back in...then buy the correct ones and try again
Old 08-09-2015, 04:34 PM
senix's Avatar
senix
senix is online now
Aftet market does not wotk for fuel or oil filter
Old 08-09-2015, 05:20 PM
Ricau's Avatar
Ricau
Ricau is offline
I'll do it
Old 08-09-2015, 06:32 PM
senix's Avatar
senix
senix is online now
Hope that you still have the old ones. Take the knock offs back and get your money.
The OEM are really the best. They are made by Racor. They are the only ones that give the correct fit due to the patents.
Especially the oil filter. Aftermarket ones will starve the motor of oil.
  #28
Old 08-09-2015, 07:01 PM
Ricau's Avatar
Ricau
Ricau is offline
Thanks. Started right up after 2nd cycle of key on/off with the old filters.
  #29
Old 08-09-2015, 07:12 PM
senix's Avatar
senix
senix is online now
Well that is good.
Grinder Man
1997-2006 Expedition & Navigator
10-10-2014 09:35 AM
Jonesy0027
12-11-2013 10:47 AM
Lowe
07-12-2012 01:53 PM
jeff2011
09-07-2009 10:54 PM
Camphill
09-28-2008 08:54 AM
Quick Reply: Procedure Fuel Filter Replacement (6.4)
