High beams dont work - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 07-11-2010, 05:18 PM
matt2491's Avatar
matt2491 matt2491 is offline
matt2491 is new and has a neutral reputation at this point.
Low beams work fine, but when I try the high beams the lights go out completely. When I pull the lever towards me (flash to pass), the high beams still don't come on but the low beams stay on. I've check the fuses and none were bad.
Old 07-11-2010, 08:07 PM
powersmoked's Avatar
powersmoked powersmoked is offline
powersmoked is gaining momentum as a positive member of FTE.
Quote:
Year? Year? Year?
Old 07-11-2010, 08:13 PM
matt2491's Avatar
Oh right, here ya go. 2002 Ford Ranger 3.0L V6 2wd Regular Cab automatic
Old 07-11-2010, 08:17 PM
I know on some years the multifunction switch is a common issue and also has a TSB. I also noticed that you have a post for the truck staying in park with the engine running. did these issues happen at the same time?
Old 07-11-2010, 08:40 PM
matt2491's Avatar
I'm not sure but I believe they are not related issues that occurred at different times. The truck is my brother's and he asked me to fix these problems (along with a few others I figured out already). He kinda let the truck gradually fall apart since he last had it inspected a year or two ago.
Old 07-12-2010, 12:44 PM
reddog99 reddog99 is offline
reddog99 is starting off with a positive reputation.
Are you sure that the bulbs aren't just burned out ? ? ?
Old 07-15-2010, 12:05 PM
matt2491's Avatar
I tried replacing the multifunction switch, but it did not fix it. How do I check the bulbs? I looked at them and they physically look alright.
Old 07-16-2010, 11:25 AM
turbochargedford turbochargedford is offline
turbochargedford is starting off with a positive reputation.
the high beams have their own fuse. i had the same problem and then i looked in the fuse pannel in the cab and their it was a blown fuse. i always jumpt to the hard stuff befor looking into the small stuff.
Old 07-16-2010, 01:28 PM
wtroger wtroger is offline
wtroger is gaining momentum as a positive member of FTE.wtroger is gaining momentum as a positive member of FTE.
Mine did that it was a 10 amp fuse in the cab fuse panel. I don't have my manual with me but I think there may also Be a relay or gem module involved in this circuit also. I will check when I get home this evening.
Old 07-16-2010, 11:33 PM
I checked the manual no relays no gems 15 amp fuse in slot 33 supplies the high beams
Per manual
Measure the resistance between the LH headlamp C1021 pin 1, circuit 12 (LG/BK), harness side and central junction box (CJB) fuse 33 pin 2; and between the RH headlamp C1041 pin 1, circuit 12 (LG/BK), harness side and CJB fuse 33 pin 2.
Are the resistances less than 5 ohms?
Yes
RECONNECT LH headlamp C1021 and RH headlamp C1041. GO to C2 .
No
REPAIR the circuit. TEST the system for normal operation
C2
Place the headlamp switch in the ON position.
Place the multifunction switch in the high beam position.
Measure the voltage between the CJB fuse 33 pin 1, and ground.
Is the voltage greater than 10 volts?
Yes
INSTALL new headlamp bulbs. REFER to Bulb—Headlamp in this section. TEST the system for normal operation.
No
GO to C3 .
C3
Measure the resistance between the multifunction switch C202b pin 5, circuit 632 (GY/OG), harness side and the CJB fuse 33 pin 1.
Is the resistance less than 5 ohms?
Yes
INSTALL a new multifunction switch. REFER to Section 211-05 . TEST the system for normal operation.
No
REPAIR the circuit. TEST the system for normal operation.
Old 07-17-2010, 10:20 AM
If you have an ohmmeter, then the bulbs can be tested by checking for an open circuit at the bulb, harness disconnected. Or plug in a known good headlight to the harness to see if it works.
Old 10-08-2010, 03:59 PM
kisucky69 kisucky69 is offline
kisucky69 is starting off with a positive reputation.
I have an 08 F150, Same thing just happened to me. Lights go out completely when I turn on the hi beams. I still get the blue hi beam light and it only when I push it forward. The low beams are working fine.
Did you ever figure out what was wrong?
Old 10-09-2010, 09:19 PM
Check the simple things first: is the light bulb good?
Many people will fail to notice only one burned out bulb. Then when the second one goes, they jump to the conclusion that both went out at the same time. So before you start looking for something complicated, check the bulbs.
Headlight Problem and Random Connector Under Dash? DaMonsterMonster 1987 - 1996 F150 & Larger F-Series Trucks 6 11-29-2015 09:23 PM
99 F250 SD CC 7.3 high beams don't work Slyder22 1999 to 2016 Super Duty 4 07-05-2013 03:13 PM
Installed new HID Headlights..Now Fog lights do not work??? Finally Powerstrokin 1999 - 2003 7.3L Power Stroke Diesel 2 10-09-2012 07:51 PM
high beams dont work, but low beams do? boggerted 1987 - 1996 F150 & Larger F-Series Trucks 2 03-21-2012 03:05 PM
High Beams Work, No Low Beams? Weezman 1978 - 1996 Big Bronco 4 09-09-2008 06:04 PM
Tags
02, 1999, 2003, 2006, 33, 96, beams, dont, explorer, ford, fuse, high, highbeams, ranger, sport, taurus, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
