Edge Insight CTS?
Edge Insight CTS?
Going to be back home soon and am looking into something to monitor the vitals of my truck more closely than the stock guages. I am considering the Edge Insight CTS. I was origionally looking into the Banks iQ, but it does not look like they are going to make that a stand alone unit (no tune) any time soon.
For those of you who have the Insight CTS do you like it? I want to be able to monitor EGT's, transmission temp, engine oil temp, and coolant temp. I know it uses the OBDII port, will I be able to monitor all of these things with the CTS?
Another concern I had was mounting it, I know they have the "dash pod", but want to keep the interior of the truck clean looking (nothing tackie). Do they offer any other type of mounting? Maybe a GPS style, suction cup to the windshield, that way I can remove it and take it out of view if need be.
Thanks!
Kyle...
Thanks!
Kyle...
Edge Insight
I have the Edge Insight in my truck. I love it. It will monitor all the vitals you mentioned plus a bunch more. It will flash different colors at you when any peramiters that you set are reached or exceded. I also have the dash pod that goes over the vent on the driver side. I was concerned with the match of the color and thought I might have to paint it to match. Once I put it in the truck though, it matches pretty dang close without having to paint. In my opinion, it is a very nice unit that I am sure you will love if you purchase it. Also with the 08-10 trucks, you dont need to buy the thermocouple cable for EGT. It monitors it from the OBDII port. Saves about $100 not having to purchase that piece.
Anyone know if they sell the dash pods to match a black interior? Or only the tan ones???
Well I made it back home finally!
I hooked up the Insight CTS yesterday, and got to use it a bit today during some errands I had to run.
So far it has been great! It starts up on it's own when I turn the truck on and shuts off by itself when I turn the truck off. It was very easy to set up what parameters I wanted it to display, and set up alerts. I will post pictures as soon as I have the opportunity to take some today.
So some questions.
What is too hot for EGT's? Engine oil temp? Engine coolant temp? transmission temp?
Right now I have the alerts set up for 1350 for EGT's, 220 for both oil temp, and coolant temp and 225 for transmission temp. Are those good settings?
So far during my city driving and about 5 miles of highway I am running at about 195-200 for oil temp and coolant temp, and have struggled to get the tranny temp much about 170. Again, that was mostly city driving and empty. Also about 85 degrees outside this morning.
Edit: I did notice that it did not seem to like the remote start. It would come on, but once I went from truck running no key in the ignition to key in the ignition in the "on" position the CTS would freeze up.
So some questions.
