1988 ranger front axle swap
Old 07-10-2010, 08:08 PM
animal12's Avatar
animal12
animal12 is offline
I have a 88 ranger 4WD date 6-88 that needs a new front end. I have found one from a 89 4WD date 11-88 . are these interchangable? The ratio is the same . the only differance I can see is the 89 has a sway bar & mine does not . (it appears that there are some extra holes in the frame where the sway bar could mount ). I can live without the sway bar I just need the new front end . so anyone know if these axles are interchangable with eaqch other. I was hoping to pull the new one with radius arms installed & pull mine with radius arms installed & just sliding the 89 right in ?
tks
mike
Old 07-12-2010, 08:56 AM
piotrsko's Avatar
piotrsko
piotrsko is offline
should fit, differences between 88 and 89 are mostly trim and cosmetics.
Old 07-12-2010, 11:52 AM
5.0B2's Avatar
5.0B2
5.0B2 is offline
same assembly - if you can get the sway bar without much additional cost - go ahead and put it on. Yours ahould have had one originally.
Da_Lariat_Chariot
04-27-2015 10:21 PM
lance65
21
01-24-2014 11:12 AM
antilla99
Ford Truck Parts for Sale
10-04-2013 06:27 PM
roscoe14eb
03-29-2011 12:19 PM
Christopher2
01-04-2005 12:36 PM
Quick Reply: 1988 ranger front axle swap
