Another deconstruction
#91
Thanks Walston.
Obviously, an affectionate term, indeed. I like these trucks better too. There are way too many Fat Fendered models to suit me. I'll stay preferring the 57 to 60 models, (and mostly my 57) to the others. My first was a 58 back in 1968, but I started driving way back in 1957, so. I am sure this will be the last truck I will ever own. It may be the last and only 57 living on the island of Oahu too. I see lots of 58-60 trucks though.
Aloha, Tony
Aloha, Tony
#93
I do have a couple open questions you might be able to confirm. During the restoration, I found black chassis paint on the original shock absorber bushing seats/cup edges. It appears the shocks were installed prior to the second chassis paint, confirm? Additionally, after scrupulously studying the archive photo you sent, it appears the brake hoses were installed before the second chassis paint, confirm? Overall, it appears the springs, steering linkage gear, brake components, exhaust hanger, emergency brake cables and components, brake lines, shocks and components, and fully assembled axle were installed before the second frame paint. The frame-mounted taillight wire harness and clips, main fuel line and hoses, engine mounts, and axle bumpers were installed after the chassis received a second chassis paint.
Any confirmation or documentation of the above would also be greatly appreciated. I hope your restoration is progressing well.
#94
I'll have to do some digging for you, I only have two underside pics, both of which you have seen I think. I do believe everything you have listed was painted on the second coat, but I'll see if I can post some assembly line photo's(truck and car) to help you make your decision.
I'm thinking the second coat was to cover things like the leaf springs and steering components and they didn't mask off anything so things like the hoses and brake cables got painted, but I'm sure it wasn't perfect coverage. Give me a few days to get you pictures.
#95
Andrew, did you have any luck locating the photos you mentioned? I'm going to pay the hourly fee to the Benson Ford Research Center to located and photocopy as many 1960 truck production line and prototype photos as possible for reference. It will be several weeks until the request is processed, but I'll definitely share what I receive if you're interested.
#98
Progress on the truck has been paused since October. I've been deployed to Afghanistan, but have been locating and purchasing parts in the meantime thanks to NumberDummy's help. Progress will resume in May upon my return. Once the u-bolts, steering center link, and a few bolt heads are powdercoated, the entire front suspension and steering system is ready for assembly. Work on the rear suspension and axle will start in June, with the entire chassis scheduled for completion around late fall. Needless to say, pictures will follow.
#99
#101
on
Unfortunately no. Overdrive was an option for the 1960 trucks. I thought about converting to an overdrive transmission, but I'm still debating. The transmission is original to the truck, and unless it can be converted to overdrive, I really don't want to swap it. The truck has spent the last eight years running at 3000 rpm on the highway daily, so I'm sort of adapted to it by now.
The original O/D's are out there, as I found one on ebay a few years ago when i had the funds.
#102
#103
#104
#105
