Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-10-2010, 02:23 PM
NDL NDL is offline
Garage is empty, add now
NDL is starting off with a positive reputation.
:::2.5L Idle Issues
Greetings!
I have an '01 Ranger with the 2.5L engine, with about 140k. The truck runs well, sans one issue that I have been having lately (which may, or may not, have gotten worse as I turn the A/C on) - engine idle.
I had the problem 4 months ago, and then it simply stopped. Last week it came back: Whether I am stopping at an intersection, or driving at any speed, the engine idle will sometimes climb. If I throw the truck into neutral, and hit the accelerator pedal, the engine idle will sometimes return to normal, although lately when I punch the pedal, the idle will climb when I hit the pedal, and stay high. The only thing that seems to reset the idle, is (while the truck is running and in gear) - clutch in, ignition key off, and back to run.
My vacuum lines look good, and the throttle cable isn't binding. Check engine light is off, and the other than this, the truck drives and (otherwise) idles fine.
I am not the most technical guy in the world, but any suggestions would be greatly appreciated. Thanks!
  #2 (permalink)
Old 07-15-2010, 10:43 AM
NDL NDL is offline
Anyone?........
  #3 (permalink)
Old 01-18-2011, 06:42 AM
greenpus greenpus is offline
greenpus is starting off with a positive reputation.
clean the TPS connector.
if that don't work, replace the IAC.
  #4 (permalink)
Old 01-21-2011, 11:33 PM
sean9901 sean9901 is offline
sean9901 is starting off with a positive reputation.
Take it to a shop and have them do a pressure test on your cylinders, i've got a '98 ranger 2.5 liter with a burnt valve in cylinder one,could be a problem, but hell worth a look
Tags
2001, 25, 25l, burnt, cylinder, engine, fast, ford, high, idle, idles, motor, problems, ranger, valves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
