side effect of disconneting egr valve - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 07-13-2010, 09:37 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
Quote:
Originally Posted by jetact View Post
You say default. Is that just a code and the CEL light coming on? I know you said it runs better and everything seems to run right. Thank you for all of your knowledge and testing that you do for us guys that are new to tearing these things apart.
read the word default as engine derate. it will limit boost to about 21psi. it wil lack soem power and the check engine lamp will come on.
and your very welcome.
  #47
Old 07-13-2010, 09:49 PM
rickatic rickatic is offline
rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.
This stand up comedy gig is harder than I thought. It might help if I had a better grasp on the English language. I was close. The word I should have used was achronyms. Is it funnier now...
  #48
Old 07-13-2010, 11:46 PM
matty169 matty169 is offline
matty169 has a good reputation on FTE.matty169 has a good reputation on FTE.
Well.......
Quote:
Hey, I was joking with you. But I do type like crap...
  #49
Old 07-14-2010, 05:00 AM
Z06MAN's Avatar
Z06MAN Z06MAN is offline
Z06MAN is starting off with a positive reputation.
Quote:
Originally Posted by cheezit View Post
just dont use the block off plate. install the egr valve were it should be and plug it in.
you will need a programer to stop it from going into default when the p0401 codes hits. this is my tested findings at this point using fords diag equipment and test tools with my own personal truck.
Thanks Cheezit!
What would cause it to trigger the p0401 code if the EGR was still installed and hooked up?
  #50
Old 07-14-2010, 09:13 AM
BossEliminator BossEliminator is offline
BossEliminator is starting off with a positive reputation.
04 EGR
My EGR started giving me problems a month ago. Stumble loss of power and black smoke. Cleaned the valve which was not very dirty and still had the same issue. Decided to test it with the valve unplugged and that resolved all the issues. I've been running it that way for about a 1,000 miles with no issues. Towed the trailer with it a couple of weeks ago and the coolant fan and AC works as normal. No check engine light and the scanner shows no codes. I still have the EGR cooler in place and going to continue to run it this way as I see no issues doing so. My last reflash was in July 04 six months after I purchased the truck.
Brian
04 F 250
EXT cab 4X4
XLT
50,000 miles
  #51
Old 07-14-2010, 09:19 AM
UGA33's Avatar
UGA33 UGA33 is online now
UGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud of
Quote:
Originally Posted by Z06MAN View Post
Thanks Cheezit!
I believe it would be lack of EGR flow measured by the IAT sensor in the intake manifold. (Hope thats right.)
  #52
Old 07-14-2010, 10:15 AM
Matty,
I saw the JK in the post. I am a little embarrassed at my English faux pas. Thanks for calling it to my attention. You did not mention if it was funnier now...
  #53
Old 07-14-2010, 07:21 PM
cheezit's Avatar
Thanks Cheezit!
yes. you will need a tune to avoid the p0401.
  #54
Old 07-28-2010, 05:20 PM
Zmann's Avatar
Zmann Zmann is offline
Zmann has a very good reputation on FTE.Zmann has a very good reputation on FTE.Zmann has a very good reputation on FTE.
just to add more info I run the previous flash #7 and Matt's tunes thru an SCT I have not experienced any issues ,, I kind of avoided the latest flash because of many recommendations ,, this is a great thread ,, I will start looking into my #'s a little more
  #55
Old 07-29-2010, 09:29 AM
Zmann's Avatar
So I had some time to play at the shop today. I grabed the IDS and starting playing with some active commands and found that when activeing the fan clutch it would NOT run at the commanded duty cycles.
So here is what is going on when I turned the fan on to 100 % duty cycle max fan speed was around 900 rpm with engine at 2500 rpm. What it should... the fan should turn at 2800+ rpm with the engine at 2500 rpm.
I cleard the egr codes from hooked my valve back up and retest. Once the codes were gone and the valve hooked up the fan will now run at 2800 rpm with engine at 2500rpm as it should.
So if you are out there and still with headstuds and running around with an unpluged or no egr valve this may solve your issues.
also as a side note after pluging the valve back in my milage may have gone up a little bit.
I wonder what the difference is when running a custom tune? Gear heads doesn't show a code with the egr unplugged , Eric's will , it doesn't throw a CEL but the code is in there
I wonder if I can read fan speed with my A?E? I will have to check this out thx
  #56
Old 08-03-2010, 08:52 PM
satwood's Avatar
satwood satwood is offline
satwood is starting off with a positive reputation.
My truck turns out to be an early '03. I have blocked off the EGR cooler and left my EGR valve plugged in. When I first started playing around with it, I found that it ran slightly better by just unplugging the valve with no other modifications. I did not leave it that way, but neither did I get a CEL. Later, after I did the modifications I cleared the memory with the batteries disconnected and have not had any CEL. I don't have the right kind of code scanner but my simple scangauge shows no codes. I don't think it can read the different layers however. As far as boost, I seem to get at least 20. I'm reading the MAP sensor with my Scangauge and doing the math on the fly but the truck seems to haul just fine.
So, maybe the '03s do not have the same programming as the later years? Is this what others have seen?
  #57
Old 08-03-2010, 10:31 PM
olfordsnstone's Avatar
olfordsnstone olfordsnstone is offline
olfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to behold
OK, I've been searching till my eyes are beginning to cross. Now, it's all about me, alright?
I have an 05 F350. I just did the egr delete. My egr is still plugged in but the cooler is G-A-W-N gone. Now I'm getting that pesky old CEL. Soooo, now it's confirmed, an 05 needs the tuner. Please set me straight on what I need to do next.
As I understand it, I need the SCT X3 with custom tunes. Where do I get one of these thingys at the best price and what are these custom tunes I need to order with it? Please help as I'm ready to lay the green on the table and want to do it right the first time.
Thanks, Tim
  #58
Old 08-03-2010, 10:34 PM
cheezit's Avatar
Quote:
this is fact and it is stated in the thread somewere If im not mistaken.
  #59
Old 08-03-2010, 10:35 PM
cheezit's Avatar
Thanks, Tim
you need an sf3 or an x3 either will work. Ive tried a few tunes from here and there. As of right now im running one of sct's canned tunes and no light all seems to be functing fine and no light.
  #60
Old 08-03-2010, 10:42 PM
SCT and their new tunes........
SCT and their canned tunes now allow you to turn off the egr. FYI, these are the new tunes SCT installed on my XF3.
Just bought an '06 6.0 - laggy and smokey - suggestions? Lead Head 6.0L Power Stroke Diesel 16 09-14-2016 04:14 PM
Does disconnecting the EGR valve effect cooling fan operation? bykr 6.0L Power Stroke Diesel 11 06-24-2016 11:56 AM
6.0 Fan Clutch question Ford12v 6.0L Power Stroke Diesel 6 05-21-2014 08:49 AM
Injector buzz test and some questions dyoung14 1994.5 - 1997 7.3L Power Stroke Diesel 10 01-22-2011 12:24 PM
Ok, I'll just pop your mind FTE Herman Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 13 12-19-2005 11:08 AM
Tags
2008, 350, 50, active, blocking, command, delete, effects, egr, f250, ford, open, stuck, test, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
