side effect of disconneting egr valve
#211
I finally got a chance to read through this whole thread and now I'm a little confused and slightly more enlightened about the effect of an unplugged EGR Valve in my '04 build PSD.
So if I'm understanding this correctly, although no code(s) will be generated, an unplugged EGR Valve in a '03-'04 build will cause some degree of insufficient fan clutch engagement, therefore higher potential for engine overheating and less efficient A/C condenser coil cooling. And that degree of insufficient fan clutch engagement may be anything from none-at-all to less-than-it-should-be?
#212
#213
I questioned whether the PCM might need a couple drive cycles of the EGR being unplugged? Just thinking out loud on that one.
I need to scrounge up an older 03/04 or retry with a newer truck with VXCF9. Just from the look of things maybe the newest strategy is the kicker with having an unplugged EGR valve?
Josh
#214
I tried with both a 2005 with VXCF7 and my 2006 VXCF4 both EGR plugged in and unplugged and the fan operated correctly @ 2500 engine rpm and fan duty cycle of 100%.
Josh
Josh
#215
#216
Definitely need the valve plugged in for the fan to operate correctly
Josh
#217
so do you happen to know what is needed to be done to a truck in calif.???...where I just happen to live with a 2004 power stroke with a welded plunged egr cooler??????
#218
I cant awnser that as I have no idea how an 05 will react at this point. you can try it both ways.
I just put mine back in and the fan is working as it now should be for the time at hand.
If you have a person that writes toons you may ask them if they even know of this concern and what they advise.
I would speculate that the 05 will have the same issue. I have no idea what the 03/04 will do as that programing is very different then the 06/07.
then I went to diesel mechanic in town and he updated my set device but .... act no longer supports egr delete which was on my unit and now disappeared, so my egr check engine light is on and I cannot fix it. I’m not able to find anyone who writes tunes. I’ve been googling for 3 days 🙈🤦🏼♀️
need help please
#219
Question?
So I had some time to play at the shop today. I grabed the IDS and starting playing with some active commands and found that when activeing the fan clutch it would NOT run at the commanded duty cycles.
So here is what is going on when I turned the fan on to 100 % duty cycle max fan speed was around 900 rpm with engine at 2500 rpm. What it should... the fan should turn at 2800+ rpm with the engine at 2500 rpm.
I cleard the egr codes from hooked my valve back up and retest. Once the codes were gone and the valve hooked up the fan will now run at 2800 rpm with engine at 2500rpm as it should.
So if you are out there and still with headstuds and running around with an unpluged or no egr valve this may solve your issues.
also as a side note after pluging the valve back in my milage may have gone up a little bit.
it's been over heating going up steep grades with and without trailer. Never hear fan kick on.
#220
Yes plug it in.
It should not need any new tune with the valve plugged in. If you have an EGR delete tune and have them update it then
you will loose the Delete part of the tune do to the EPA sticking there noses up everyones back side. So the effect will be
if you update the tune you will get a dash light for EGR flow. Also if you do talk to your tune people do not say you have
EGR delete. Some of the tuners have gone to the dark side. They will ask you to prove your have EGR intact before they
will send you an updated tune.
#221
Yes plug it in.
#222
indyraven
07-06-2013 10:42 PM
hakukamana
04-23-2013 04:53 AM
