side effect of disconneting egr valve - Page 15 - Ford Truck Enthusiasts Forums
  #211
Old 07-23-2014, 10:12 AM
jfirstford's Avatar
jfirstford jfirstford is offline
jfirstford is gaining momentum as a positive member of FTE.
I finally got a chance to read through this whole thread and now I'm a little confused and slightly more enlightened about the effect of an unplugged EGR Valve in my '04 build PSD.
So if I'm understanding this correctly, although no code(s) will be generated, an unplugged EGR Valve in a '03-'04 build will cause some degree of insufficient fan clutch engagement, therefore higher potential for engine overheating and less efficient A/C condenser coil cooling. And that degree of insufficient fan clutch engagement may be anything from none-at-all to less-than-it-should-be?
  #212
Old 07-24-2014, 08:12 AM
bcfarmer bcfarmer is offline
bcfarmer is starting off with a positive reputation.
From my understanding that is correct.
  #213
Old 09-13-2014, 12:26 AM
Bullitt390's Avatar
Bullitt390 Bullitt390 is online now
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Quote:
Originally Posted by cheezit View Post
Josh I was only able to varify the concern with vxcf9. Never had a code in my either, just wasnt able to activate the cooling fan correctly with ids
I tried with both a 2005 with VXCF7 and my 2006 VXCF4 both EGR plugged in and unplugged and the fan operated correctly @ 2500 engine rpm and fan duty cycle of 100%.
I questioned whether the PCM might need a couple drive cycles of the EGR being unplugged? Just thinking out loud on that one.
I need to scrounge up an older 03/04 or retry with a newer truck with VXCF9. Just from the look of things maybe the newest strategy is the kicker with having an unplugged EGR valve?
Josh
  #214
Old 09-13-2014, 09:51 AM
Restlesswildman Restlesswildman is offline
Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.
Josh
If you were in Ohio I would be your guinea pig! lol
  #215
Old 11-05-2014, 11:08 AM
woodlander's Avatar
woodlander woodlander is offline
woodlander is gaining momentum as a positive member of FTE.
So I guess this means that on my 206 with VXCF9H7 I have to leave EGR valve in. I was so hoping I could use my fancy aluminum block off plate with the RCD engraved on it. I guess I can hang on wall of my shop.
  #216
Old 11-05-2014, 11:26 AM
Bullitt390's Avatar
Quote:
You can use a plug, just need the valve plugged in and laying in the valley or zip tied to something
Definitely need the valve plugged in for the fan to operate correctly
Josh
Just bought an '06 6.0 - laggy and smokey - suggestions? Lead Head 6.0L Power Stroke Diesel 16 09-14-2016 04:14 PM
Does disconnecting the EGR valve effect cooling fan operation? bykr 6.0L Power Stroke Diesel 11 06-24-2016 11:56 AM
hesitation,surge stumble, over 1500 RPM 18inchapes Excursion - King of SUVs 16 01-28-2015 12:58 AM
hesitation,surge,miss detanation over 1500 RPM 18inchapes Modular V8 (4.6L, 5.4L) 0 01-23-2015 05:31 PM
6.0 Fan Clutch question Ford12v 6.0L Power Stroke Diesel 6 05-21-2014 08:49 AM
Tags
2008, 350, 50, active, blocking, command, delete, effects, egr, f250, ford, open, stuck, test, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
