'92 E4OD Band adjustment-easy to do?
Old 07-08-2010, 10:58 PM
92 Red F150's Avatar
92 Red F150
92 Red F150 is offline
I am going to drop the E4OD trans oil pan on my '92 2WD F150/300 CID, drain the converter, replace the filter and refill. Do the bands require an adjustment and would this be a good time to do it? If so, how do you do it?
Thanks
Old 07-09-2010, 04:19 AM
Lazy K's Avatar
Lazy K
Lazy K is offline
Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles Here is a link to a great writeup on what you propose to do.
As far as I am aware there are no adjustments possible on that trans.
Old 07-09-2010, 07:37 AM
92 Red F150
Thanks for the link LK, excellent write up. I just thought there might be some sort of band adjustment on these E4ODs as the bands wear and that this would be a good time to do it. Thanks.
Old 07-09-2010, 09:16 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,571 Likes on 1,049 Posts
Bands? What bands? There is one band in the E4OD. It is used when the transmission is in second gear and ONLY when the shifter is also in the 2 position. This band is not adjustable.
Old 07-09-2010, 09:46 PM
92 Red F150
Mark,
Don't know much about Ford transmissions as you can tell.
Thanks for clarifying.
blucolarboy
05-30-2009 02:30 PM
Jrock909
06-08-2007 11:09 PM
ksvtwin
05-17-2004 12:43 PM
92 Red F150
03-19-2004 09:41 AM
78fordman
11-03-2003 04:19 PM
Quick Reply: '92 E4OD Band adjustment-easy to do?
