'92 E4OD Band adjustment-easy to do? - Ford Truck Enthusiasts Forums
Old 07-08-2010, 10:58 PM
92 Red F150 92 Red F150 is offline
92 Red F150 is starting off with a positive reputation.
I am going to drop the E4OD trans oil pan on my '92 2WD F150/300 CID, drain the converter, replace the filter and refill. Do the bands require an adjustment and would this be a good time to do it? If so, how do you do it?
Thanks
Old 07-09-2010, 04:19 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles Here is a link to a great writeup on what you propose to do.
As far as I am aware there are no adjustments possible on that trans.
Old 07-09-2010, 07:37 AM
Thanks for the link LK, excellent write up. I just thought there might be some sort of band adjustment on these E4ODs as the bands wear and that this would be a good time to do it. Thanks.
Old 07-09-2010, 09:16 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Bands? What bands? There is one band in the E4OD. It is used when the transmission is in second gear and ONLY when the shifter is also in the 2 position. This band is not adjustable.
Old 07-09-2010, 09:46 PM
Mark,
Don't know much about Ford transmissions as you can tell.
Thanks for clarifying.
trans. help for 92' f150 blucolarboy Clutch, Transmission, Differential, Axle & Transfer Case 2 05-30-2009 02:30 PM
95 F-150 Mass air E4OD computer? Jrock909 1987 - 1996 F150 & Larger F-Series Trucks 5 06-08-2007 11:09 PM
transmission band adjustment? ksvtwin 1987 - 1996 F150 & Larger F-Series Trucks 8 05-17-2004 12:43 PM
'92 E4OD Neutral Safety Switch-Do I have to align it? 92 Red F150 Clutch, Transmission, Differential, Axle & Transfer Case 2 03-19-2004 09:41 AM
band adjustment on e40d 78fordman Clutch, Transmission, Differential, Axle & Transfer Case 1 11-03-2003 04:19 PM
Tags
92, a4od, adjusting, adjustment, adjustments, amount, automatic, bands, clutch, e40d, e4od, eo4d, ford, problems, refill, tansmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
