trac-loc sounds question
Hello,
i've rebuilt my 9" ford rearend, and put a trac-loc in it with a 3.25 gearing.
Now, i test drove the car, and the trac-loc makes all kinds of noises. (when NOT going in a straight line, so when cornering)
To describe them, i'd say they sound like disk-brakes when braking with worn-out pads: metal-to-metal, so to say.
Also, there is a bit rotational play in the right axle. You can turn the wheel a bit front to rear and rear to front, before it takes the other wheel with it.
I only tested it with town cruise speeds, no highway yet.
When cornering slowly, as sayd, i hear the noises.
When i drive backwards (to park the car) it "clunks".
It does this also when i make a "S" turn, so from left to right, and then directly from right to left, for instance on a roundabout.
Does these sounds and descriptions sound familiar, or did i do something wrong with the build?
Is it possible that these sounds are from the clutches, needing to run-in?
I used a standard gear oil.
i bought the centersection with the trac-loc as it is now, being new. (there were some styropur packaging ***** in the gears, and marking dye on the tooth, so i can safely say that it is a new one.)
i go on a long trip in about 5 days from now, so i need to know if it's allright.
Any help highly appreciated, thank you.
edit:
I poured the neat little bottle of skunk smelly friction modifier (CM-19546-A1, the green stuff...)
I don't know what little gozmo's and wizard's of Oz created the friction modifier, but after 100 feet no clunk or scatter anymore...
I made a small testdrive of a few miles at various speeds and bends: As smooth as a baby's butt...
I'm stunned..
edit:
I'm stunned..
Last edited by dutchlincoln79; 07-10-2010 at 06:29 AM. Reason: updated knowledge :)
Uncle Grumpy
18
04-02-2009 03:14 PM
fattmann
10-10-2006 01:42 PM
bluedevil
02-03-2005 08:44 PM
Annihilator
03-02-2004 06:07 PM
