Changing heater core in a 78 with air sucks! - Ford Truck Enthusiasts Forums
Old 07-08-2010, 06:52 PM
redsuperduty's Avatar
redsuperduty redsuperduty is offline
redsuperduty is gaining momentum as a positive member of FTE.
My 78 lariat started leaking from the air box drain tube, I knew it had to be the heater core. Let me tell you, that was a chore to get apart. The whole heater box must come out from under the hood and the a/c evaporator has to be removed from the box to get to the heater core. I noticed my evaporator was turning green and rotting at the bottom too, so I replaced it too. The heater core was only 30. bucks, but the evaporator was $300.00 !!. Just got her back together today, no leaks and ice cold a/c. (I had some R12 laying around from the good ol days) Boy am I glad to be done with that!
Non a/c trucks are easy, beware if your truck with a/c starts leaking from the core.
Old 07-08-2010, 08:31 PM
hasteranger's Avatar
hasteranger hasteranger is offline
hasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud of
guess thats what I have to look forward to if mine ever fails! Lucky that you had R12 around. I've heard its still available in mexico...
Old 07-08-2010, 08:51 PM
79Indy's Avatar
79Indy 79Indy is offline
79Indy is starting off with a positive reputation.
Yep, that's one of my least favorite repairs ever. I did mine from inside the cab.
Old 07-08-2010, 08:59 PM
Blown 331's Avatar
Blown 331 Blown 331 is offline
Blown 331 is gaining momentum as a positive member of FTE.
Thats what I've heard. I changed the heater core in my non-AC 1977 and it was easy. My uncle has a pretty decent 1979 F-150 Ranger with limited slip front and back. It is an AC truck and the heater core started leaking probably 10 years ago. He just stopped driving it! I think he got it runing about a year ago and apparently one of the valves was sticking from old gas and it bent a push rod. Wow, I think that one is about done for. Its a tutone red and sliver, nice truck.
Old 07-08-2010, 09:12 PM
steponit steponit is offline
steponit is gaining momentum as a positive member of FTE.
Old 07-08-2010, 09:26 PM
lsrx101 lsrx101 is offline
lsrx101 has a very good reputation on FTE.lsrx101 has a very good reputation on FTE.lsrx101 has a very good reputation on FTE.
Quote:
It's actually very much available in the US, too. The price has also dropped dramatically in the last few years. The last #30 cylinders I bought were $300, that's $10/lb. Just about the going rate for R134a.
Old 07-08-2010, 09:47 PM
Quote:
Where do you get it from? I need to restock for some other old vehicles I've got.
Old 07-08-2010, 09:59 PM
smokeyb97's Avatar
smokeyb97 smokeyb97 is offline
smokeyb97 is starting off with a positive reputation.
My heater core went bad several years ago and got an estimate for replacement at $600. I decided to just do it myself. I did it through the inside. NEVER again. After six hrs. of that crap I would have been happy to pay.
As far as my a/c goes it has never cooled correctly since swapping to R134.
Ebay and Craigslist.
A lot of folks still think it's liquid gold, but if you're quick you will catch the deals. I recently missed a sealed #30 jug for $200 by about an hour on CL.
Old 07-08-2010, 10:08 PM
ranger429 ranger429 is offline
ranger429 has a good reputation on FTE.ranger429 has a good reputation on FTE.ranger429 has a good reputation on FTE.
Sorry but that is incorrect. I have replaced the heater core and the blower motor in an A/C equipped 79 Bronco and took neither of those items off to do it. While it is not the easiest job to do it is not necessary to remove the box from the firewall.
Quote:
I think through the inside or pull the box sucks about equal. I had a hard time getting the whole box out and back in, but switching the parts was easy while it was laying on the bench.
Hopefully neither of us have to do that job again!
Old 07-08-2010, 10:12 PM
Quote:
Your right, you can do it from the inside. I don't think it's any easier either way, but I GUARANTEE you have never changed a heater core without pulling the evaporator on an a/c truck..
Old 07-09-2010, 03:19 AM
ATC Crazy's Avatar
ATC Crazy ATC Crazy is offline
ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.
Mine just started leaking after I put the 466 in it. Non-AC though...
Old 07-09-2010, 04:59 AM
there may be differences between factory air and dealer installed air, too....
Old 07-09-2010, 06:53 AM
Yes there are. Dealer installed air is much easier IIRC.
Keep Blowing Heater Cores! 1974xlt 1973 - 1979 F-100 & Larger F-Series Trucks 15 03-26-2016 06:49 AM
WTB 77 heater box and plenuim factort a/c mjr46 WTB - Parts & other 4 11-10-2015 12:53 PM
can mouse get pass evaporator? over top mike L 1987 - 1996 F150 & Larger F-Series Trucks 9 08-12-2014 12:46 PM
A/C evaporator box/ recirculation door housing?? chad85 1973 - 1979 F-100 & Larger F-Series Trucks 4 01-12-2014 11:53 AM
HELP!! heater core removal with dealer AC!!! dakonthemountain 1973 - 1979 F-100 & Larger F-Series Trucks 4 09-22-2011 10:04 PM
Tags
1979, 77, 78, air, changing, core, dealer, f100, f150, ford, heater, installed, pickup, remove, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
