1997 F150 CD Player Stuck! - Ford Truck Enthusiasts Forums
Old 02-09-2003, 06:42 PM
dbell4x4 dbell4x4 is offline
dbell4x4 is starting off with a positive reputation.
Unhappy 1997 F150 CD Player Stuck!
Has anyone ever had their multi-disk cd player jam? I try to play a cd and the radio display NO DISK, or maybe no cd, but you know what I mean. Has anyone ever fixed this before? I have the player full of cd's.
Old 02-10-2003, 04:52 PM
Fordtrucktexan Fordtrucktexan is offline
Fordtrucktexan is starting off with a positive reputation.
Had it do it once before, turns out disc 1 was in upside down.
Also mine seems to be real scratch sensitive, if there's a scratch on track 1 it'll act like the whole disc just isn't there. Try starting the disc on track 2, that trick hasn't failed me yet.
FYI: My truck came with a factory 6-disc cd changer mounted on the driver's side extended cab panel.
Old 02-10-2003, 08:28 PM
Matt_W Matt_W is offline
Matt_W is starting off with a positive reputation.
If by multidisk you mean a changer the same thing happened to my 97' F-150. Actully The head unit shorted out somehow at almost the same time. When i was looking to find a replacement i came across a website that repairs stock stereos. you should be able to find it by searching for car stereo repair on google or something. Its not cheap though. You are probably off buying a new deck, at least thats what i did, but be warned an f-150 with a premium sound system (seperate factory amp) can be a pain to wire up. there arent any "plug in" harnesses to integrate that amp. Hope this helps some
Old 02-10-2003, 09:17 PM
98f250lightduty 98f250lightduty is offline
98f250lightduty is starting off with a positive reputation.
My disk changer in my 98 sticks sometimes and says no cd when I know the things full of cds. I reach back there and wiggle the cd holder inside the changer and keep hitting the eject button till it finally lets go of it. Then I simply push it back down and itll usually plays after that.Give it a try.
98 F250 ld s/c xlt 4x4
5.4L
CD Stuck in 6 Disk CD Changer Whitey Ford 6.0L Power Stroke Diesel 18 01-15-2013 01:23 PM
6-disk CD player indicates cassette empty? BaitGuru Expedition & Navigator 5 09-15-2009 09:02 PM
2002 F150 stock radio won't play CD's mikef56 1997 - 2003 F150 1 10-25-2006 12:53 PM
Factory CD player for 2002 F150 04SilverSCFX4 1997 - 2003 F150 5 08-17-2004 01:08 AM
6 Disk in dash CD player, worth the "upgrade" ? How much ?? mbnv992 1999 to 2016 Super Duty 23 04-05-2003 06:04 PM
Tags
1997, 1998, 2008, cd, cds, changer, disc, f150, ford, jammed, player, quit, sporttrac, stuck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
