Timing a 460 & set advance - Ford Truck Enthusiasts Forums
Old 07-08-2010, 11:08 AM
Powerstrokin_350's Avatar
Powerstrokin_350 Powerstrokin_350 is offline
Powerstrokin_350 is starting off with a positive reputation.
I have a 79 460, and was wondering with all the experience out there, whats the best setting to put my timing at? I had it around 12 degrees. What, if anything, is better? Its stock with edelbrock carb, headers and 3 inch exhaust. Also, with the vac advance, what is the best way of setting it period? when all hooked up and running high rpms what should my timg be? Please help, I need it running top notch for friday night!!!! Thanks!!!!
Old 07-09-2010, 02:00 PM
Bobcat7 Bobcat7 is offline
Bobcat7 is starting off with a positive reputation.
Starting advance with the vac-adv disconnected and plugged should be 8-12 (may even be on the factory sticker in front of the radiator)
4000 rpm with the vac-adv disc and plugged could be 36-38 maybe 40.
As far as the setting with the vac-adv connected... If it pings - retard it. In the mud there is no real need for vac advance as you are either in it to the rugs or idling. On the highway is when vac-adv makes sense and useable power.
I have always set as high as I can get away with w/o pinging and/or knocking during light acceleration, or at any time for that matter.
Pinging is a bad deal for a motor - like a little hammer hitting the top of the piston with every ping...
460 timing gear set Brnfree 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 08-03-2016 10:06 PM
1986 E350 w/460 - distributor setup dvguy 1968-2013 Full Size Vans 5 08-28-2013 11:20 PM
Recurve on 460 - starting point? Myfreeford Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 10 03-29-2012 05:37 PM
'79 460 timing '94Nichols 1978 - 1996 Big Bronco 2 08-18-2010 01:31 AM
460 timing issues yeahbuddy24 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 22 12-07-2009 10:56 PM
Tags
460, 75, 79, 95, 96, adjust, advance, big, block, f350, ford, set, setting, specs, time, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
