1996 F250 460 baseline dyno results and head porting-RESULTS ARE IN!
#106
Hey, if you're going dig up something this is the one to grave rob
The thing about this is how much time and money does it cost to do all of this? Bo was in a unique position were he had the experience, time and equipment available. But most of us don't. Yeah, I could port my own heads and build my own intake (fab or modified stock) but I don't have the time or equipment. I could pay someone to do it (I contacted Bo about this. He said he could and would do it but with his schedule it wouldn't be fast or cheap) but I'm on a budget and can't have my truck down that long. Or I could just get a set of aftermarket heads and use a readily available aftermarket EFI setup. The work is already done and it would perform better than any modified stock parts and it's just a matter of bolting it all together and going. It would still be expensive but that extra cash would pay for the support system built into these products and the time it would save me trying to get it right.
I'm glad Bo showed us what stock parts are capable of. And I fully support anybody that wants to build upon his effort. But for most of us this will just be the stuff of day dreams and bench races.
#107
#108
Now if you want utter simplicity and no electronics or computers to mess with, that's fine and it makes sense for some (primarily if you need on-the-trail repairability with simple hand tools and on-hand spare parts).
#109
From my research not too much Eagle. You have to swap the heads and intake of course. Most of the wiring and emissions can be eliminated and the truck will still run. The EFI fuels pumps can be retained. You have to bypass the switch to make them run constantly and use a return style regulator. With a C6 you don't have to worry about a trans controler (something that makes me hesitant to do this myself with a E4OD). I haven't done this but there are a couple of writes ups on here and down in the 385 series forums. Use the search feature and see what you find. And if you try it, please, take a bunch of pictures and open a project thread here.
#110
#111
He's posted a few times in the past few months. He's currently working a few projects for the EFI 460 trucks. He's been updating his thread under the 385 series engine forum rather than this one.
https://www.ford-trucks.com/forums/9...ts-are-in.html
#112
#113
Yep, still here and still playing with this thing Put 24# injectors in it for fun (had them around) and and still completely out of fuel so next step is the fuel pump trick the lightening guys do. Anyone got a helpful link on how to do so? Going to try that first to keep it cheap otherwise going to put a Bosch 044 inline which I have here from another project. The new standalone/piggyback ECU is getting close, just trying to play with it a bit - and not melt pistons down in the process. Thanks for the interest,
Bo
Bo
#114
#117
#119
#120
