1996 F250 460 baseline dyno results and head porting info-RESULTS ARE IN!
Old 03-24-2012, 06:53 PM
4inchlovin's Avatar
4inchlovin
4inchlovin is offline
Also I might add that if you do have so many questions perhaps posting them in a new thread instead of high-jacking bo's thread would be good forum mannerds also. Just my .02c
  #107
Old 09-21-2012, 02:26 PM
Sirscootsalot's Avatar
Sirscootsalot
Sirscootsalot is offline
Subscribed!!
  #108
Old 09-25-2012, 08:01 PM
1800joedaddy's Avatar
1800joedaddy
1800joedaddy is offline
Is there anything more or is this thread going to die in a hailstorm of derail?????
  #109
Old 09-25-2012, 09:30 PM
4inchlovin's Avatar
4inchlovin
the OP Bo is a very busy guy with his porting buisness and i know spends alot of time on other forums for his 4cyl turbo ford heads that he sells so i doubt he checks FTE much but i will throw him a text and let him know yall want more info haha
  #110
Old 09-25-2012, 10:12 PM
1800joedaddy
Fair enough, I've done a bit of grinding myself and am curious of the eventual #'s.
  #111
Old 12-03-2012, 03:33 PM
mountainsurfer's Avatar
mountainsurfer
mountainsurfer is offline
Through all this I never saw on accurate cc capacity for the F3TE heads. Does anyone have that. I'm in the process of building a 521 and need that spec for the kit builder. Thanks
  #112
Old 12-03-2012, 03:55 PM
85lebaront2's Avatar
85lebaront2
85lebaront2 is offline
Old School Hot Rodder
Go to 460ford . com and ask Scotty aka the mad porter.
  #113
Old 12-03-2012, 04:01 PM
mountainsurfer
Thanks, appreciate it.
  #114
Old 12-04-2012, 06:40 PM
jokerforever's Avatar
jokerforever
jokerforever is offline
Hey bud, if you get the answer can you repost it here. That way we'll have a one stop for all of this great info.
  #115
Old 12-04-2012, 07:14 PM
mountainsurfer
Scotty said the F3TE heads were around 95cc's.
  #116
Old 01-31-2013, 03:40 AM
Boport's Avatar
Boport
Boport is offline
Ruh Roh....
More to come soon....
  #117
Old 01-31-2013, 09:52 AM
DIYiT's Avatar
DIYiT
DIYiT is offline
Originally Posted by Boport
Ruh Roh....
Looks like you found a Vortech kit. Looking forward to seeing what you have to share.
  #118
Old 01-31-2013, 03:13 PM
ceetwarrior's Avatar
ceetwarrior
ceetwarrior is offline
Cool, looking forward to results! My setup was 468, stock f3 heads that I just cleaned up, custom torquer cam, 5psi vortech and it made 305/420 rwhp/rwtq thru 35x12.5's. Your's will be much more, sweet!
  #119
Old 02-07-2013, 06:23 AM
Boport's Avatar
Boport
Boport is offline
We are working on re-producing this "kit" as it has been so hard to locate and it seems the interest is still very much there. It will be available with a "plug and play" piggy-back ecu, injectors, in line fuel pump, cnc ported heads, optional cam, many different stages. Don't mean to make this a sales pitch but there is a lot we are working on right now for the old 7.5L EFI and we are expecting 500-600whp on 91 octane pump gas easily. I have some of the best tuners and connections in the industry to make this happen, and it seems like the demand is there to reproduce a modernized bolt-on kit version of the vortech kit that was available back in the day.
I sponsor and work closely with this racer Matt Culpepper (also a lightning guy) sponsored by myself and Stinger Performance. This is a STREETABLE 9 second door slammer pump gas 4 banger on ported factory iron heads block and manifold. Just to give you an idea of what we are capable of.....The plug and play "PIMP" ECU we are working on will basically the same hardware as the ECU in this 9 second 4 banger pass in the vid.
Old combo with mild porting, small .400" lift cam, T5 trans, not very good tune up:
New combo**** (much better vid!!!!) ****with basically same head but larger (still tiny) /.520" 240@.050" solid roller cam, 20# boost, little bigger turbo, Doug Nash 5 speed trans, A LOT of chassis breaking/tuning/work, P.I.M.P ECU tuned by someone who all I can say was heavily involved with Ford's Roush-Yates E.F.I. Cup cars.
I want to see some 3 ton GASSERS giving some Powerstroke, Durascatter and Cummins a run for their money! Well, maybe not the fuel MPG Dept
  #120
Old 02-07-2013, 06:36 AM
Boport's Avatar
Boport
Boport is offline
Thanks dude! I ended up getting that kit in Wyoming you sent me the link to. A customer/friend of mine picked it up for me who was in CO only a half hour a way or so. Thanks for your help locating it, and I'll be happy to help any way I can with your kit. I'm getting the mounting plate reproduced so we can have these available at minimum for these EFI 7.5 truck engines, the rest is easy stuff. FMU's are oldschool, we need a new completely programmable ecu, bigger pump and injectors. At 8:1 these things are DYING for boost.....I see no reason why we can't manage 600whp out of this stock shortblock. I made 500+whp out of a stock pinto shortblock a third the size and with a lot lesser flowing heads. I dont see why 600 at the tires would be an issue with the old V-1 and this trans. I love me some BBF!!!! Stay tuned!
Quick Reply: 1996 F250 460 baseline dyno results and head porting info-RESULTS ARE IN!
