1996 F250 460 baseline dyno results and head porting info-RESULTS ARE IN!
#166
Fascinating product plans. One question: how updatable will the programming be? That is, will the "smarts" be on an upgradable EPROM or similar mechanism such that as experience accumulates, that experience can be incorporated into "profiles" that optimize various use cases (street, street/strip, strip, pulling [LD or SD])?
Thread started in 2010 and boport hasn't been available to answer any questions for a very long time.
It's doubtful you'll get a reply. Sorry
As far as your question/statement, there are a lot of options for your tuning needs. Quarter horse and tweecer, and even an sct chip via Dyno shops. That's only a few that utilize oem ecu. If you had a manual trans, you can retrofit a mustang sefi ecu and mass air, and be opened up to many more options.
#167
You can go further if you want to go up to the EEC-V processor. The only thing you need then is the correct hardware code for your equipment, E4OD requires a truck EEC as it was never in any cars.
I am running a reflashed 1996 351 EEC-V box in my truck and tuning it with BE2012. I tried setting my TwEECer RT up, but for some reason it does not work with the EEC-V two bank system.
#168
#169
#170
Nope. Never made it to a complete kit. But the theory and all the work has been done and documented so that you can duplicate it. All you need to do is find a good tuner or get the software to tune yourself. Fast efi is pretty good, but won't work if you have the e4od trans. There's lots you can do with the stock efi. No need for aftermarket fuel injection.
#173
on
that really gave it a kick in the pants i bet.i mean 8:1 from a 460,really? that's just not gunna produce the grunt from so many cubes like it should.i bet that turned out good.
#174
I actually ended up only going .030 over, 9.23:1 compression and using a Sig Erson 26021 cam. I was helping a friend with his 454 Chevy converting a 1995 TBI engine to a 1996 Vortec system (MAF/SEFI) and he built marine engines for years. Blueprinted, balanced, Scorpion roller rockers.
I have it completely assembled, just need time when I am not using the truck and some help to yank the front end off so I can install it.
#176
#177
#179
#180
