Overload Shocks? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Overload Shocks?
Old 07-07-2010, 12:46 PM
FX4_4x4's Avatar
FX4_4x4 FX4_4x4 is offline
FX4_4x4 is starting off with a positive reputation.
Overload Shocks?
So I saw an add on craigslist for some overload shock for a ranger... well they wouldn't fit my truck, but they got me thinking... I do a generous amount of towing and load on the bed of the truck... nothing over Ford specs, but if I can help the truck last longer... why not? so what are your thoughts on the shocks?
Monroe Sensa-Trac Load Adjusting Shock Absorbers - Ideal for Varying Loads or Tow Trailers
they are load adjusting, and designed for heavier weights... I'm not a fan of the air shocks, but I thought this could potentially be a nice upgrade for the rear of the ranger....
Thanks
Rafal
Old 07-08-2010, 12:59 AM
1965f100factory4x4's Avatar
1965f100factory4x4 1965f100factory4x4 is offline
1965f100factory4x4 is starting off with a positive reputation.
i can remember right, shocks dont hold any weight themselves. springs are what holds the weight. all those probably do is help keep it from excesive recoil.
Old 07-18-2010, 06:28 PM
hvacguy's Avatar
hvacguy hvacguy is offline
hvacguy is starting off with a positive reputation.
Have you looked at the Roadmaster Active Suspension? I use it on my Excursion and it works great. They make it for the Ranger.
Old 07-21-2010, 01:26 AM
racsan's Avatar
racsan racsan is offline
racsan is gaining momentum as a positive member of FTE.racsan is gaining momentum as a positive member of FTE.
i dont go for the overload shocks, you are putting alot of stress on the shock mounts. i do like (and have) overload coils. mine are 1,200 pound rated. i know autozone has some 1,500 pound rated ones locally ( i put a set on the taurus to fix a weak strut spring issue) here is a pic of my ranger rear suspention. the coils dont touch the frame when the truck is unloaded. they come in contact with the frame at about when 200 pounds is in the bed. i think i paid about 25-30 bucks for the kit, comes with 2 springs and the u-bolts. the loop you see under the axle is a hose i slid over the bottom of the u-bolts to protect the threads. this set of springs i had on my first ranger, a '88 and i figure if i part ways with this truck someday, i'll keep the springs for the next one, again. and for those who are curious, heres a pic of my taurus suspention with a overload coil, in this case the spring is in constant contact with the underbody of the car, yes it rides rougher, but the headlight aim was horrible and the car was scraping its but over speedbumps. not now.
Old 07-21-2010, 05:16 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
air shocks are fine for enabling minor adjustments in ride height, but overload/assist springs IMHO are best if you are towing something consistant that requires the additional capacity. Today's air shocks are much better than the originals in the 70's, which were basically "air sticks" (my terminology)- they typically caused a stiff ride, poor handling due to lack of give and during avaisive maneuvers where known to promote vehicle roll-over. Todays units use air to adjust the height but typically integrate a conventional shock assembly into the internals for general performance.
Old 07-22-2010, 01:35 AM
Peter94's Avatar
Peter94 Peter94 is offline
Peter94 is gaining momentum as a positive member of FTE.Peter94 is gaining momentum as a positive member of FTE.
Keep in mind the shock mounts are designed to withstand far more load than you can imagine. I honestly cant say that i've seen any ever break off. I would not be worried about the extra load. Plus, the springs do not feel very stiff anyway. I've installed these in multiple vehicles. They work nice, but they are not as stiff as you would think.
Need shocks for my 59 F100 4x4 chetspencer 1957 - 1960 F100 & Larger F-Series Trucks 7 01-13-2014 11:16 PM
Suspension and handling upgrades. KhanTyranitar Aerostar 53 08-31-2013 09:34 PM
load adjusting shocks F250 HD George84 1987 - 1996 F150 & Larger F-Series Trucks 4 10-12-2011 11:28 PM
Monroe load adjusting shocks vs reflex shocks 93f250tn 1987 - 1996 F150 & Larger F-Series Trucks 0 01-14-2011 01:49 AM
Are Monroe Sensatracs good shocks for a truck? rambaseball45 1997 - 2003 F150 10 03-24-2009 01:53 AM
Tags
1994, 2009, air, excursion, f150, ford, forums, overload, overloaded, overloads, ranger, shock, shocks, truck, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
