Wrench symbol on dash - Ford Truck Enthusiasts Forums
Old 07-07-2010, 12:34 PM
Bodger's Avatar
Bodger Bodger is offline
Bodger is starting off with a positive reputation.
I was on way to the airport yesterday and th yellow wrench light came up on the dash, didnt notice any loss of power or anything else wrong. turned of the engine and it went away for a while and then back on. Thismorning it didnt start like it should, any ideas please........Ive not had the truck back that long after the dealers screwed me over my warrenty... Thanks for your time.
Old 07-07-2010, 12:39 PM
cubalz's Avatar
cubalz cubalz is offline
cubalz is starting off with a positive reputation.
The wrench symbol is the same as "check engine" Your truck is throwing a code that something is wrong. Get a code reader hooked up to your OBDII port to find out what is going on.
Old 07-07-2010, 01:01 PM
Bodger's Avatar
Ok will do, I wasnt sure i will go now and see, thank you.....
Old 07-07-2010, 01:28 PM
Cowboy65's Avatar
Cowboy65 Cowboy65 is offline
Cowboy65 has a very good reputation on FTE.Cowboy65 has a very good reputation on FTE.Cowboy65 has a very good reputation on FTE.Cowboy65 has a very good reputation on FTE.
I think the engine symbol is more closely related to a check engine light. Whereas the wrench symbol indicates problems with the electronic throttle control. In either case you should check the codes to determine the problem.
Old 07-07-2010, 02:31 PM
florida_1959 florida_1959 is offline
florida_1959 is starting off with a positive reputation.
could be that it is the EOT/ECT out of range if you have the recent flash. Had that show on mine and thats what it ended up being. And I confirmed with a code read and also running it and watching the point where it came on while observing the two temps get past the 15 degree limit. Now Im setting myself up to replace the coolers.
Old 07-08-2010, 09:22 AM
Cowboy65's Avatar
There is some info in TSB 09-24-3 regarding problems that cause the wrench light to illuminate.
Old 07-10-2010, 08:53 AM
Bodger's Avatar
Ok thanks, i have the lateset flash, and havent had it come on again so will just have to wait to see what happens. It is still hard to start in the morning though. I will have to go get a new code reader cant seem to find mine. Thanks again for the info guys...
Old 07-10-2010, 02:41 PM
matty169 matty169 is offline
matty169 has a good reputation on FTE.matty169 has a good reputation on FTE.
What were you doing??????
Here is what I have seen. High humidity and outside temps in the 80's, full egr delete and tunes from Elite or SCT. Cruising at a steady speed of 70 for about 25 miles and A/C on high. Wrench light comes on, 22 degree spread of eot/ect. AC off it doesnt seem to come on. Towing it comes on within 20 miles unless I turn A/C off. Put egr valve back in and NOW the engine cooling fan comes on and the wrench light seems to stay off. fyi
Old 07-11-2010, 09:52 AM
Bodger's Avatar
You have just hit the nail on the head !!!! I was cruising down the highway on a hot day with ac on. The only thing i have had the EGR valve disconected for the last 3/4 months. I have pluged it back in now. I have instaled an Edge Juice with Attitude which i leave on #1 Mileage. I havnt had the light come back on yet but also i havnt been down the highway. But now its not wanting to start very well it fires but wont start straight away. I have just changed the oil and for the first time put a wicks filter the one with the lid on the filter, Im hoping its that. I am going to get a MC one and put it in. Fingures crossed.
Thanks Ben
Old 07-11-2010, 10:57 AM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
1. Cheazit has found that eliminating the egr valve screws up the cooling fan protocal.
2. Edge Juice and the 6.0/5R110 don't get along too well over the long haul.
Old 07-11-2010, 02:55 PM
Bodger's Avatar
I have heard about the Edge but i thought if i kept it at the mileage setting it would be fine... If not tell me and i will remove it because it realy doesnt make that much difference.
Old 07-11-2010, 03:04 PM
russ3873 russ3873 is offline
russ3873 is starting off with a positive reputation.
my truck didn't want to start after ford worked on it.turn out to be glow plugs not hooked up on one side
Old 07-11-2010, 03:11 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
Quote:
hey matty if you find out anything else before me on this let me know please. Its been rather hot and humid here and after not hearing mine come on for over a week when I figured it should at least once with the ac on I went diggin for the reason.
If I have time Im going to do somemore looking as to the effect when there is a no flow code.
Old 07-11-2010, 03:13 PM
cheezit's Avatar
bodger I would check charging system voltage and ficm voltage. either of those will also turn on the wrench light and also make hard starts.
Old 07-11-2010, 06:34 PM
Bodger's Avatar
Ok will do, the ficm is new and so are the batts. Ive had nothing but trouble since those dumb f***s at Kelleher Ford - Brandon, Manitoba. Worked on it. Im going to put a MC filter in on monday i didnt like the one they sent me. Thanks.
Wrench Light with No Codes strokenboost Modular V8 (4.6L, 5.4L) 2 08-22-2016 10:49 AM
The "wrench" Vinford 6.4L Power Stroke Diesel 27 07-14-2014 11:57 AM
wrench light on dash came on paddler65 6.0L Power Stroke Diesel 20 05-07-2012 05:55 PM
Wrench symbol hansen 6.4L Power Stroke Diesel 5 04-01-2012 09:02 AM
Torque wrench short enough for 5.4 L spark plugs? PEG 1997 - 2003 F150 5 02-22-2011 10:42 PM
Tags
2010, 60, control, dash, e350, electronic, f150, f250, ford, indicator, light, loss, power, symbol, throttle, wrench
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
