1995 302-351 swap - Ford Truck Enthusiasts Forums
1995 302-351 swap
Old 07-07-2010, 09:57 AM
1995_f150 1995_f150 is offline
1995_f150 is starting off with a positive reputation.
1995 302-351 swap
I have a 1995 f150 with a 302. I was wondering how hard it would be to swap it out wit a 351 or if I should just go with a 302 again. Or should I rebuild the 302 thats in it. It has 221,xxx miles on it. What do you think I should do?
Old 07-07-2010, 10:08 AM
nstueve's Avatar
nstueve nstueve is offline
nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.
351w are a better overall truck motors. 351w are in plentiful supply so you could probabl find one although you will have to get a 351w with all the fuel injection and intake manifolds. you computer and tranny should work just fine... although the motor mounts might be different... How much are you wanting to spend? what is the overall use and purpose for the truck??? Need more info before we can tell you what you might want to consider.
Old 07-07-2010, 10:14 AM
I would like to spend the smallest amount possible. I used the truck for hauling and pulling and would continue to do the same with it.
Old 07-07-2010, 10:21 AM
nstueve's Avatar
if you are hauling and pulling with it... The best thing would be to get a 351w with EFI... Maybe find one that needs a head gasket but has a good short block/bottom end. That way you can refresh the 351w with new gaskets and seals replace water and oil pump and you'll have a motor ready to go into your truck... This way a swap can be done in a a weekend. your 302 is ok for hauling a pulling but probably not ideal. What is wrong with it that you are wanting to rebuild or replace??? Just remember when shopping for and engine you should get one that has a good rotating assembly because other wise you are looking at a big machine shop bill.
like i said you best options would be to find a cheap, low milage, complete 351w... freshen it up and swap it in over a weekend.
your absolute cheapest option would be to get good running cheap 302 and slap it in... rebuilding a ford small block is never the cheapest solution after the machine shop, new parts, and all the time you'll have in it. take a look at this wikipedia page at the 92-96 gen fords... it will show you the power and torque ratings...
http://en.wikipedia.org/wiki/F150
Old 07-07-2010, 10:24 AM
Ok thanks. The 302 thats in there has high miles started leakingoil bad and now sometimes wont start or turn over other times it will. Would a 351 bolt right in? or would I have to change the mounts up?
Old 07-07-2010, 10:48 AM
nstueve's Avatar
the mounts I am unsure about... they are both sbf engines so it might bolt right up but if it doesn't you should just pull them from a junk yard truck for $10... i made addition to my previous post..
Old 07-07-2010, 10:56 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
The 5.8 uses the same engine mounts and bolts to the same tranmissions, but it requires a 28oz flexplate (5.0 has a 50oz version), and because it is physically wider and taller will require a 5.8 specific Y-pipe or modifications to the 5.0 Y-pipe. There are also a lot of unique parts on the 5.8 that won't transfer from the 5.0 so you will need a complete 5.8 EFI to swap in. I have done this swap and it's really not that bad, no wiring or computer changes necessary as long as your truck is mass air, and the 5.8 is a far better truck motor so it's easily worth the effort if you're pulling the motor anyway. Things you can re-use from the 5.0 are the accessory brackets and starter, injectors, throttlebody, and all sensors and actuators.
Well I would rather have enough power. Would I be better of swaping the tranny out also?
Old 07-07-2010, 11:01 AM
Conanski's Avatar
Don't change the transmission of you don't have to, if anything change the axle gearing to 3.73 or 4.10.. especially if your truck now has 3.31 or 3.08 gears.
Old 07-07-2010, 11:06 AM
My trans slips already. What would be my best way to go with that if I went with the 351w?
Old 07-07-2010, 11:20 AM
nstueve's Avatar
we are talking about this in another post right now... try doing a couple things first
A.) pull codes and see if those tell you anything
B.) change the tranny fluid and filter you'd be surprised at what a fluid change can do...
read here for more info.
http://www.ford-trucks.com/forums/96...ew-tranny.html
You should have a E40D and a good one at that... The earlier 90's had problems that should be factory fixed in yours... If you are slipping I would suggest trying a fluid change and see if that makes a difference b4 you pull the 302. If not talk to your local parts store guys... they could probably give you the name of a tranny mechanic that could do a weekend rebuild for 1/2 the price and would be a better option than getting another 2nd hand tranny that might go bad in a year... Tranny guys are usually always willing to do a cash side job... At least the ones around here are...
Old 07-07-2010, 11:25 AM
nstueve's Avatar
all this being said you might want to take a look on your local craigslist to find a 351w truck that will already have all you need. I can pick up parts trucks for $300 here in iowa... plus you and strip extra parts and send the rest to the junk yard for $150 once your done! Just a thought. Trucks that have been recked or have a bad rear end or bad tranny would be a good cheap find for you...
Old 07-07-2010, 05:41 PM
Thanks for all the information. Im looking at getting a 351w. Would the wireharness be different? Would I have to change it?
Old 07-07-2010, 10:56 PM
nintey4f150's Avatar
nintey4f150 nintey4f150 is offline
nintey4f150 is starting off with a positive reputation.
as conaski has said this swap isnt that bad at all i too have done it.. i had a complete 351 intake to pan that i swapped in place of a 302.. jus need the 28oz flexplate and would have to do something about the y pipe i myself jus got the exhaust redone.. i used all the same wiring as long as your truck is mass air u wont have a problem
Old 07-08-2010, 12:21 PM
nstueve's Avatar
1995_F150 just find yourself a complete 351w complete from intake to pan... Also get the origional flexplate with it and you'll be fine! I know you can pull one in the yard by me complete for $250... If it were me I would just do that and haggle for the 351w y pipe and flex plate to be included.
If you do go used and get a cheap one like that I would stop by the parts store for a 351w gasket set... Also take a battery, gas and compression tester with you. Test all your cylinders and hopefully get it running to hear it. As long as you get a decent short block the rest should be cake! Also inspect your motor mounts... if they are shot you might want to replace those while engine is out. I would also suggest a new oil pump, screen, and fel-pro pan gasket. The oil pumps are a PITA if you have to do them later!
351 swap SouthDakota95F150 1987 - 1996 F150 & Larger F-Series Trucks 2 11-16-2016 01:28 AM
1995 F150 351W Build Thread TexasGuy001 1987 - 1996 F150 & Larger F-Series Trucks 183 08-03-2016 03:13 AM
1995 F150 351W Lightning mass air conversion 95centurion 1987 - 1996 F150 & Larger F-Series Trucks 4 04-08-2016 04:39 PM
1995 F150 with 302 MAF to 351w roller swap Timdnj Engine Swaps 5 02-19-2016 11:45 AM
1996 f150 302 to 351 BAKAFLAKA Engine Swaps 2 10-13-2015 01:12 PM
Tags
1988, 1989, 1995, 302, 351, 351swap, 49, 95, engine, f150, ford, ideal, mount, ottawa, swap, truck, yard
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
